Drives: 2013 GT86
No cats
So far I've put on a catless Gruppe-S header & overpipe. I've got the quiet rumble now and would like to liven it up a bit more.
I don't have to have a cat where I live. Should I ditch the second cat for a straight pipe with the stock rear muffler? Or would I be better to replace the rear muffler as well? Basically I'm wondering if the next restriction to replace after the header & over-pipe is the second cat or the OEM muffler? |
#2 | |
Drives: 2013 Brz WRB
Edit: actually im 100% sure replacing OEM catback would make liven it up more... |
Drives: 2014 GT86
2nd cat doesn't impact exhaust that much as one in header (which you removed by getting catless header), which was the main performance killer. I wouldn't expect much from changing frontpipe's cat to high flow one and i wouldn't want to eliminate altogether unless it's race only car not used daily thus not having to deal with MOT inspections and alike. You may get some on top of catless header gains, but it will be minimal. What you'll get certainly in fully catless exhaust - it will be much louder.
Drives: brz
catless front pipe will add a little more sound and little more power. catback will give you the biggest difference in sound. really depends how loud you want to go
Drives: 2013 GT86
I don't want to go too loud, just want a nice rumble and to be able to hear it when I put my foot down. I suppose if the second cat isn't much of a restriction and makes it too loud without it, maybe I should just leave it..
Perhaps I'll just get a 2.5 cat-back and see what it's like and I can always cut out the second cat later. |
Boost Creep
Drives: 2016 HyperBlue BRZ
It all depends what you go with, man. N1 style with single cat is louder than my full catless Perrin. By a quite a lot. I would imagine the stock CBE might get raspy if you delete both cats, too, but I can't confirm.
FR Noob
Whatever you do don't make it sound like this guy's..
[ame="https://www.youtube.com/watch?v=EwdEQ-9_gHo"]Scion Fr-s Borla UEL header w/Straight pipe (THIS - YouTube[/ame]
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in |
Drives: 2014 Scion FRS
Drives: 2013 GT86
well since I'm in NZ I've got cheaper access to X-Force products than US ones. I guess most of you have probably never hear of them?
http://www.xforce.com.au/bolt-on-sys...0/vid-99002065 I've been told 100CPSI cat won't make much of a difference over the OEM one. So for me it would either be no cat at all or leave OEM cat there with a cat-back 2.5 system. |
| Gutting out the stock cats | diss7 | Engine, Exhaust, Transmission | 90 | 04-02-2018 12:57 AM |
| Just replacing the stock cats? | brillo | Engine, Exhaust, Transmission | 4 | 07-08-2015 11:12 AM |
| How Cats Work Part 1 | Magna_Flow | Engine, Exhaust, Transmission | 13 | 03-17-2015 03:14 PM |
| OEM cats only ? | 350matt | Engine, Exhaust, Transmission | 7 | 11-26-2013 07:30 PM |
| I giggled... Cats have it made | seven | Off-Topic Lounge [WARNING: NO POLITICS] | 51 | 12-21-2012 03:46 PM |
