Old 06-26-2012, 01:27 AM   #1
Silver Bullet BRZ
Silver Bullet BRZ's Avatar
BRZ/Bluetooth/iPhone
Okie dokie....first one with the correct answer wins a cookie. (Flavor to be determined at a later date.)
Question: In my BRZ, when using Bluetooth with my iphone and playing music, is there ANY way to get the search function working on the head unit screen?
At this point all I can do is track forward and backward but not select playlists, artists or anything else - AND - you can't select playlists on the iphone as the ipod function is locked out being connected by bluetooth.
I know the obvious solution is to just run bluetooth for phone and then run audio out through the dock connector seeing as how its plugged in to charge anyway but I was trying to avoid having to select a source on the iPhone everytime its plugged in - OR better yet, not have to plug the phone in at all and just use Bluetooth the way one might hope it was designed to work.
Thoughts?
"The Silver Bullet" / 2013 Subaru BRZ Limited / Sterling Silver Metallic
Silver Bullet BRZ is offline   Reply With Quote
Old 06-26-2012, 01:51 AM   #2
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
The iPhone only supports a fairly basic version of the AVRCP bluetooth profile (the profile for media control). From http://support.apple.com/kb/HT3647:
Audio/Video Remote Control Profile (AVRCP)
Audio/Video Remote Control Profile allows remote control of playback functions on the iOS device from compatible devices (commonly Bluetooth devices that use the A2DP profile). iOS supports the following commands: pause, play, stop, next track, and previous track.
Sorry , It does seem that the head unit fully implements the AVRCp profile version 1.4, which would allow for searching, etc. See http://en.wikipedia.org/wiki/Bluetoo...le_.28AVRCP.29 for more info.
cmspooner is offline   Reply With Quote
Old 06-29-2012, 05:27 AM   #3
Silver Bullet BRZ
Thanks cmspooner
Looks like iOS 6 will bring iPhones up to full functionality when it is released in the fall.
Oh and I did promise a cookie...
Old 06-29-2012, 01:48 PM   #4
cmspooner
cmspooner's Avatar
Originally Posted by Silver Bullet BRZ View Post
Thanks cmspooner
And that's good enough for me!
If it makes you feel better, my Droid Charge doesn't even send track info.
Old 03-06-2014, 01:10 AM   #5
cpedrow13
Drives: White 2013 Subaru BRZ
Has anyone had connectivity issues using an android device such as the Samsung galaxy s4? Every once and a while my phone connects just fine. But most of the time it just connects and disconnects like every 30 seconds. Even when I shut off the blue tooth the unit still figures out how to screw with me. At this point i'm fed up. Any input would help!
cpedrow13 is offline   Reply With Quote
bluetooth, brz, iphone
Bluetooth Audio... Loathe it. seannyice81 Electronics | Audio | NAV | Infotainment 35 10-26-2013 02:10 PM
Bluetooth/Nav inimitable Electronics | Audio | NAV | Infotainment 40 09-26-2012 08:35 PM
Bluetooth built into head unit? finch1750 Electronics | Audio | NAV | Infotainment 8 06-16-2012 02:59 PM
BRZ Bluetooth issues? Shizuma Electronics | Audio | NAV | Infotainment 3 06-13-2012 12:06 AM
Bluetooth Mic Placement in 86? Aventador87 AUSTRALIA 13 06-11-2012 01:36 AM
