Old 06-19-2012, 08:40 AM   #1
inimitable
inimitable's Avatar
Drives: SSM 6-MT limited
Bluetooth/Nav
I'm just wondering how anyone would rate their Bluetooth connection...
I've never been much of a fan of anything Bluetooth, as I've never had very stable success with any of the devices I've used, therefore, I've used it very little. However, it seems to be the most convenient way of playing the music I have stored on my phone. No cords required, and the data such as track title, album name, and artist name are transferred as well, which is a big bonus, as opposed to using the aux. input; I have yet to try the USB because it only supports up to 8gb, and the memory card is currently 16gb. The other thing I was considering doing, though I have to read about it in the manual, is possibly using the SD card slot, along with an adapter, and trying to play music and/or videos from there.
In any case, back to Bluetooth. I get frequent cut-outs, often multiple times while driving, even though, it typically does manage to reconnect. The phone is right in front of the display, blocked by nothing. I don't know where the actual BT receiver is, but I'd imagine that it's built into the display itself. Nonetheless, the signal strength is appearing as only 1/2 bars on the display.
I haven't had any other BT problems with my phone (Samsung Galaxy SII Skyrocket), connecting a keyboard or mouse, or to my computers.
Is anyone else having similar problems?
Does anyone know of a way to boost the BT signal?
inimitable is offline   Reply With Quote
Old 06-19-2012, 08:45 AM   #2
DantKR
Drives: Subaru BRZ LT
9/10. No cut outs so far. Sound quality is good. Can next/back from the touch screen which is a major plus.
DantKR is offline   Reply With Quote
Old 06-19-2012, 09:16 AM   #3
Shizuma
Shizuma's Avatar
Drives: 2015 Dodge Challenger SXT
I'd rate my bluetooth connection at god awful, worst device i've ever used for stable bluetooth connection, actually the only bluetooth device i've ever had that lost a connection at all, the Kenwood headunit I had in my Magnum connected and never onced disconnected.
I have found out a work around for the crappy bluetooth connection that I read on an Impreza forum since they have the same headunit, disable auto connect on the headunit and manually do it on the phone, it works, it hold connection pretty good and rarely drops, but it's a pain in the ass having to go into the settings on my phone everytime I get into the car to manually connect it.
Also I only have 1/2 bars for bluetooth connection strength, even if I hold my phone directly in front of the headunit.
Shizuma is offline   Reply With Quote
Old 06-19-2012, 09:22 AM   #4
DantKR
Mine auto connects 100% of the time within 10 seconds of the head unit being booted up. And stays connected. Maybe there are some issues with your head unit?
Old 06-19-2012, 09:32 AM   #5
feedbag
Seasoned Spirit
Drives: 2013 DGM BRZ Premium
For calls it's fine other than people sometimes not being able to hear me when I'm going 70 - 80, the bluetooth audio implementation sucks though. Immediately upon switching to Bluetooth Audio mode it'll try to start playing some random sound files from my android phone (in my case a bunch of notification noises) rather than simply sitting there and waiting for me to start playing stuff on my phone. In some cases if I do start playing music on the phone it'll make the head unit freak out and drop the bluetooth connection.
Voice recognition is alright, don't try to make it recognize the word 'Morgan' though or else it'll go crazy.
Also no Aha Radio support as far as I know, but their app sucks anyways so that's not a huge deal.
feedbag is offline   Reply With Quote
Old 06-19-2012, 09:33 AM   #6
DyoGTS
DyoGTS's Avatar
Drives: '13 BRZ Limited
My bluetooth connection, as far as auto connecting and audio quality, has been fantastic. Connects every time without issue.
I have found that if I am streaming Pandora from my phone over bluetooth, and I turn the car off without killing the stream, the next time it auto connects I only get 5% of the audio volume until I turn the car off and on again (is there a way to turn the head unit off entirely rather than just 'volume off'?)
DyoGTS is offline   Reply With Quote
Old 06-19-2012, 09:42 AM   #7
DookDookDGM
BR-Zizzle
DookDookDGM's Avatar
Drives: 2013 BR-Z, 1985 AE86, 1986 AE86
Send a message via AIM to DookDookDGM
Bluetooth works ok for me as long as I'm not using my PS Vita.
A little addiction goes a long way...
2013 Dark Grey Metallic Subaru BRZ
1986 Toyota Corolla GT-SR5
1985 Toyota Corolla SR5
DookDookDGM is offline   Reply With Quote
Old 06-19-2012, 10:51 AM   #8
inimitable
inimitable's Avatar
Thanks for the tip!
Mind giving me a shortcut on how to disable it? I'm out for most of the day and I don't have the manual with me. I will try and fool around with it and see whatI come up with though.
I will try it out today and give some feedback.
Old 06-19-2012, 10:59 AM   #9
Shizuma
Shizuma's Avatar
Originally Posted by inimitable View Post
Thanks for the tip!
If I remember correctly when you're in bluetooth audio mode and and in phone mode there is a setting button and inside the settings is where you can turn off auto connect, you have to disable it in both of those modes for it to work.
Supposedly some phones will auto connect on their own and it's fine, but I've read that Samsung phones don't, something with the way Samsung programmed the bluetooth in their customized android OS, my phone doesn't initiate auto connect on it's on and it is a Samsung, the Galaxy Note.
Old 06-19-2012, 11:01 AM   #10
Tbxgz
Tbxgz's Avatar
Drives: 2013 BRZ Limited 6MT
8/10. No dropped calls, connects immediately, and sound clarity is perfect. Only docked 2 points because the head unit failed to import my contacts. (Motorola Droid Bionic)
Tbxgz is offline   Reply With Quote
Old 06-19-2012, 11:13 AM   #11
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
9/10 Mine setup easily, imported my contacts and connects quickly everytime I get in the car. No issues other than call volume, which I can fix by playing with the settings.
Samsung Behold II Droid
Opie is offline   Reply With Quote
Old 06-19-2012, 11:17 AM   #12
inimitable
inimitable's Avatar
Maybe I should've mentioned that my only experience so far has been with the audio; I haven't gotten around to setting up support for handling calls & texts or voice-dialing
In any case, with BT left on on my phone, typically, I'll get recognition and support/connection when I first get in and start the car. Everything will work fine for a little while, then it will start losing connection, albeit reconnecting some of the time. Furthermore, often when it reconnects, I lose the metadata displayed, and this seems to indicate to me a more unreliable "connection," as it will inevitably drop out again soon. Typically, at that point, I give up and go with the old faithful auxiliary input.
I'm wondering what kinds of phones/OS everyone is using, those with no issues, and those with issues? Please leave that information in your posts in this thread.
I Googled "Why does Bluetooth suck" and one of the first threads i came across was on androidforums where someone posted an issue with his phone and his BT earpiece; he said he has constant issues reconnecting once out of range of the device, which he attributes to what he believes could be poor Bluetooth implementation by Android since he didn't have problems with the same devices using his older windows phone. He didn't mention what version he was running, and the issue didn't get much discussion nor a resolution, but it still can help us in troubleshooting.
Samsung Galaxy SII (skyrocket) running Android 2.3.5 Gingerbread.
Old 06-19-2012, 11:27 AM   #13
inimitable
inimitable's Avatar
Thanks.
Btw, I envy your phone. How is it? I was so disappointed when I saw the commercials because I had just gotten my phone like a month or two before. I'm happy with mine, but more screen real-estate was what I was after, and the stylus would have been ideal as well.
Old 06-19-2012, 11:29 AM   #14
Indestruct
Drives: 2013 SWP Limited BRZ, MT
I may be wrong but you can import your contacts when you aren't driving. When you are driving it doesn't let you scroll through your contact list, you need to use the "handsfree" command. Or you can use Speed Dial or recent calls.
The Bluetooth function gets a 9/10. The NAV Function gets a 2/10, It has frozen on me and caused me so much heart ache!!! Pure crap.
Indestruct is offline   Reply With Quote
Bluetooth audio from android phone cgrey Electronics | Audio | NAV | Infotainment 10 07-11-2013 07:56 AM
Bluetooth built into head unit? finch1750 Electronics | Audio | NAV | Infotainment 8 06-16-2012 02:59 PM
BRZ Bluetooth issues? Shizuma Electronics | Audio | NAV | Infotainment 3 06-13-2012 12:06 AM
Bluetooth Mic Placement in 86? Aventador87 AUSTRALIA 13 06-11-2012 01:36 AM
Sound quality of Bluetooth streaming music robo_robb Electronics | Audio | NAV | Infotainment 20 06-08-2012 11:37 PM
