Old 11-28-2015, 10:21 AM   #1
Fred Flintstone
Drives: 2015 FR-S Asphalt, racing stripes,
Worthy upgrade or not?
Front and rear strut tower brace for a daily none track driver. Any need.
Fred Flintstone is offline   Reply With Quote
Old 11-28-2015, 11:00 AM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
No. I have them. unless you find a great deal on a set (sub $50 USD) no worth it in my opinion
Freeman is offline   Reply With Quote
Old 11-28-2015, 11:57 AM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
These are only for looks on a DD. They only make a very slight difference at the absolute limit of traction. They will make a slightly bigger (but still not much of a improvement) if you run R rated tires , but again this is at or near the absolute limit of traction.
On the other side some people claim (no idea if this is true) that over many years a sturt brace can help a car keep its chassis rigidity.
Old 11-28-2015, 12:17 PM   #4
mrk1
Drives: Sterling BRZ Ltd
I noticed a difference with my front. Rear makes no sense to me as there is no lateral force through the rear mounts.
To me the improvement from bracing is subtle but I know that when I install them. I think they get a bad rep when people have unrealistic expectations.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 11-28-2015, 12:43 PM   #5
Fred Flintstone
Thanks for your replies. What is the best suspension upgrade for highway driving???
Old 11-28-2015, 12:44 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Lol whats your budget??
Old 11-28-2015, 12:53 PM   #7
Fred Flintstone
$1000
Old 11-28-2015, 12:58 PM   #8
_gt86_user
Inactive
Drives: .
Maybe some ST's or just get swift springs and call it a day.
_gt86_user is offline   Reply With Quote
Old 11-28-2015, 01:03 PM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
$1000
Then I would leave it stock.
If anything you could do some RCE springs or TRD springs if you want to lower it a bit and they work well with stock shocks but it will make the ride stiffer for sure. You could also buy some good tires because that will give you the biggest gains in handling for that price point. Also invest in camber bolts (they are cheap) and get a little more camber in the front then the rear to improve handling.
The biggest bit of advise I can give you is don't cheap out on suspension because this car is already very well designed so its hard to improve apon cheaply.
Again as you said you want to improve it for the highway I would leave it stock and save your money.
Old 11-28-2015, 01:04 PM   #10
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
I forgot about swift springs. Highly recommended those if you go that route.
Old 11-28-2015, 02:00 PM   #11
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Bilstein B14.
Old 11-28-2015, 02:08 PM   #12
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Originally Posted by jsimon7777 View Post
Bilstein B14.
Those are a good pick but out of his price range, plus he will need LCA's if he lowers it more then an inch and wants to keep his tires from getting wrecked if he does a lot of highway driving. (Too much negative camber for the highway)
Old 11-28-2015, 04:39 PM   #13
strat61caster
strat61caster's Avatar
Ordered mine from Raceseng last week with ten percent off, $900 shipped to my door. They had 20 percent off yesterday, that deal might still be good.
You can put camber bolts in stock lcas to stay under two degrees I believe. An alignment should be done no matter what coilover is installed and this will affect every option so far proposed.
Edit no idea if they will be "better" on the highway.
ineedyourdiddly
Old 11-28-2015, 04:47 PM   #14
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Man at that price then that seems like a great upgrade!!! I am sure they will offer a more planted feel on the highway and have great high-speed dampening. Maybe the OP should go the same route as you! I was going to get Bilstens but I didn't like the fact they are progressive but they seem like a really nice unit from all my research.
Roads worthy of a Vacation Blu-by-U Off-Topic Lounge [WARNING: NO POLITICS] 37 04-05-2015 02:05 PM
MT Upgrade Tansey86 Forced Induction 14 09-19-2013 07:13 AM
Topspeedautosport.com , trust worthy? ChandlerSwyng User/Vendor/Sponsor Reviews, Feedback, Comments 0 09-05-2013 10:48 AM
Anyone done a show car worthy audio build on these yet? Vamanos Electronics | Audio | NAV | Infotainment 16 03-08-2013 06:29 PM
HU upgrade briang0901 Electronics | Audio | NAV | Infotainment 15 11-05-2012 11:17 AM
