Drives: 2003 Subaru Outback
MT Upgrade
It seems like every part of this car has a stronger upgrade for it aside from the manual transmission. I thought by now there would a PPG set or something out for this transmission.
Aside from swapping it out for a stronger one that includes custom fab work and more headache than its worth, is there a way to make this transmission handle a decent amount of power?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Drives: 2007 Impreza, 2013 BRZ
The crawford build is holding up to 450hp, so I'd say it isnt doing too bad
just my 2cents |
#3 | |
Boosted
Drives: Not a supra....yet
. The Tranny isnt rated for high hp, and has been a hit or miss with people at high HP
Evasive is working on a replacement trans. Don't know details though.
NASA SpecE30 Racer
I have seen very few failures, so I don't know where this view is coming from. What do you consider "a decent amount of power"? Have you been talking to Don & John?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
Drives: SSM LT MT BRZ
The fundamental issue with "upgrading" a transmission internally is, the real limit is found when the case starts to deform from the pressure of the gears trying to push eachother away.
Yeah Don has a tranny swap available but im more specificly interested in making the stock unit stronger, if at all possible.
Grip>Slip
Evasive Motorsports? Talked to them and they have no plans on doing any replacements.
#10 | ||
blowhard
Drives: frs, project forester
This sort of thing is offered for the subaru 5speed. Quote:
#11 |
Drives: FRS
mine holds up well i changed the fluid and added the stiff trans mount
still going
#12 |
Adding a pump and oil cooler will go a long ways towards your transmission holding up under higher loads.
When I was researching transaxles for a race car I wanted to build, I found Porsche transaxles rated for 180hp were magically uprated to 219hp with the only difference being an oil cooler. A simple, inexpensive setup could use tapped filler and drain plugs with a pump. More elaborate setups have internal spray bars and other stuff. Bad juju happens when things gets hot. |
#13 |
#14 | |
Drives: Hydra EMS Powered FRS Raven Black
| The big 3 upgrade | crazyfrenchbiker | Electronics | Audio | NAV | Infotainment | 22 | 12-19-2018 04:26 PM |
| Need to upgrade the oil pan for the FRS/BRZ? | Hanakuso | Engine, Exhaust, Transmission | 5 | 12-28-2014 12:54 PM |
| HU upgrade | briang0901 | Electronics | Audio | NAV | Infotainment | 15 | 11-05-2012 11:17 AM |
| Anyone Looking To Upgrade Their LSD? | SpeedBRZ | Engine, Exhaust, Transmission | 27 | 07-19-2012 06:33 PM |
| FR-S HID Upgrade? | frsinpa | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 06-18-2012 08:43 AM |
