Drives: 2015 FR-S Asphalt, racing stripes,
Worthy upgrade or not?
Front and rear strut tower brace for a daily none track driver. Any need.
#2 |
Drives: 2013 Ultramarine FR-S
No. I have them. unless you find a great deal on a set (sub $50 USD) no worth it in my opinion
#3 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
On the other side some people claim (no idea if this is true) that over many years a sturt brace can help a car keep its chassis rigidity. |
#4 |
Drives: Sterling BRZ Ltd
I noticed a difference with my front. Rear makes no sense to me as there is no lateral force through the rear mounts.
To me the improvement from bracing is subtle but I know that when I install them. I think they get a bad rep when people have unrealistic expectations.
#5 |
Thanks for your replies. What is the best suspension upgrade for highway driving???
#6 |
Not Bаnned Anymore
Lol whats your budget??
#7 |
$1000
#8 |
Inactive
Drives: .
Maybe some ST's or just get swift springs and call it a day.
#9 |
Not Bаnned Anymore
Then I would leave it stock.
If anything you could do some RCE springs or TRD springs if you want to lower it a bit and they work well with stock shocks but it will make the ride stiffer for sure. You could also buy some good tires because that will give you the biggest gains in handling for that price point. Also invest in camber bolts (they are cheap) and get a little more camber in the front then the rear to improve handling. The biggest bit of advise I can give you is don't cheap out on suspension because this car is already very well designed so its hard to improve apon cheaply. Again as you said you want to improve it for the highway I would leave it stock and save your money. |
#10 |
Not Bаnned Anymore
I forgot about swift springs. Highly recommended those if you go that route.
#11 |
Dismember
Drives: 2013 Red Scion FR-S
Bilstein B14.
#12 |
Not Bаnned Anymore
Those are a good pick but out of his price range, plus he will need LCA's if he lowers it more then an inch and wants to keep his tires from getting wrecked if he does a lot of highway driving. (Too much negative camber for the highway)
#13 | |
Drives: '13 FRS - STX
You can put camber bolts in stock lcas to stay under two degrees I believe. An alignment should be done no matter what coilover is installed and this will affect every option so far proposed. Edit no idea if they will be "better" on the highway. |
#14 | |
Not Bаnned Anymore
| Roads worthy of a Vacation | Blu-by-U | Off-Topic Lounge [WARNING: NO POLITICS] | 37 | 04-05-2015 02:05 PM |
| MT Upgrade | Tansey86 | Forced Induction | 14 | 09-19-2013 07:13 AM |
| Topspeedautosport.com , trust worthy? | ChandlerSwyng | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 09-05-2013 10:48 AM |
| Anyone done a show car worthy audio build on these yet? | Vamanos | Electronics | Audio | NAV | Infotainment | 16 | 03-08-2013 06:29 PM |
| HU upgrade | briang0901 | Electronics | Audio | NAV | Infotainment | 15 | 11-05-2012 11:17 AM |
