Old 11-27-2015, 09:41 PM   #1
BRZach
SupaSter
BRZach's Avatar
Drives: 13' BRZ
Running UEL untuned?
Hello all,
I feel this has been somewhat talked about, (yes I searched), but I would like to get someones opinion who has credibility. I received a Gruppe-S header and am anxious to install it, for obvious reasons. Unfortunately I don't have money to tune it until I sell a few parts, and so I was wondering how harmful would it be to run the UEL without a tune for about a month or so? I wouldnt beat on it, rather just enjoy the new sounds since the AFR's wont be ideal. Then tune and have lots of fun when I can.
Anyway, I'm sure I'll get somewhat roasted, but hell, Im excited like anyone would be.
Thanks!
BRZach is offline   Reply With Quote
Old 11-27-2015, 09:43 PM   #2
Teseo
Drives: frs
Agreed, search
Teseo is online now   Reply With Quote
Old 11-27-2015, 09:51 PM   #3
BRZach
SupaSter
BRZach's Avatar
Drives: 13' BRZ
Originally Posted by Teseo View Post
Agreed, search
Stated I have already. No one says you cant, Im asking will I be alright for about a month without tune and easy driving..
Old 11-27-2015, 09:56 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by BRZach View Post
Hello all,
Thanks!
Only thing you will harm is the environment haha. Stock tune is safe but does run really rich and that may make it run even richer. I wouldn't worry about it you just may get a little black on your tail pipes. You won't see much performance gain until you tune though and will have a CEL.
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
BRZach (11-27-2015), FRSBRZGT86FAN (11-28-2015)
Old 11-27-2015, 09:56 PM   #5
azynneo
Hello all,
Thanks!
People say you should be fine, but your CEL might turn on
azynneo is offline   Reply With Quote
The Following User Says Thank You to azynneo For This Useful Post:
BRZach (11-27-2015)
Old 11-27-2015, 09:59 PM   #6
mrk1
Drives: Sterling BRZ Ltd
Will it run, yes. Is it the correct thing to do, no. Are you getting your money's worth from your header, no. Best off containing your excitement however long it takes to save up for a tune. Why not look after your car.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 4 Users Say Thank You to mrk1 For This Useful Post:
BRZach (11-27-2015), Freeman (11-28-2015), FRSBRZGT86FAN (11-28-2015), kch (11-30-2015)
Old 11-27-2015, 10:12 PM   #7
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
One of the oldest FRS' out there, (first one in VA might I add), is at ~115k miles, 60k of them w/ an untuned UEL. Why? no idea but he's my buddy so I have to accept him lol.
No harm to do it. Won't get the 'performance' aspect of the header until it's tuned, however. And if you CEL comes on, say bye-bye to cruise control. Won't work until you clear the codes.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
The Following User Says Thank You to Rifle For This Useful Post:
BRZach (11-27-2015)
Old 11-27-2015, 10:30 PM   #8
steve99
It will be fine
Your only issue will likely be cel code P0420 comming on every few hundred miles (cat efficiency) and cruise control will be disable if that code ective just clear it with obd scaner of android torque app . You can reset cel code by removing battery terminal but that will reset ecu and you will likey notice the thrttle is a bit laggy till ecu relears a few parameters.
The headers wont upset afr unless you fitt them incorrectly and have air leaks.
Intake changes upset afr due maf sensor readings can be different.
Tune will disable p0420 cel code permanetly and optimise valve timing fueling and ignition timing for best performance.
BRZach (11-27-2015)
Old 11-27-2015, 10:32 PM   #9
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Spend that money on an OFT or equivalent before you get the header, is what I would do (what I did).
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
BRZach (11-27-2015)
Old 11-27-2015, 10:43 PM   #10
BRZach
SupaSter
BRZach's Avatar
Drives: 13' BRZ
I have a custom tuner I plan to go to, once my extra parts sell. Header is here, therefore I cannot do that. Wanted to get everything first so I didnt have to retune/tweak for every new part.
In all, thanks to those who replied. I will most likely install them soon if I can find the time between studying and finals!
Appreciate it all!
Mods, I found my answer so thread can be closed.
Old 11-28-2015, 06:35 PM   #11
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Then go to your tuner, pull the stock rom off, disable p0420 then reflash. Takes a whole 10 min.
The Following User Says Thank You to Wayno For This Useful Post:
Ultramaroon (11-28-2015)
Old 11-28-2015, 06:42 PM   #12
Ultramaroon
not playing cards
Ultramaroon's Avatar
This is not a classified ad. Your question and the answers have now become part of the vast body of knowledge that is ft86club dot calm.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
BRZach (11-29-2015), Cole (11-28-2015), Cop (11-29-2015), FRSBRZGT86FAN (11-28-2015), Tcoat (11-28-2015)
Old 11-28-2015, 07:39 PM   #13
86Hiro
Which O2 sensor needs the eliminator plug? Mine has the CEL after I installed it
86Hiro is offline   Reply With Quote
Old 11-28-2015, 08:03 PM   #14
Ultramaroon
not playing cards
Upstream is for closed-loop metering. ECU compares downstream conditions with upstream to determine cat efficiency.
Running E-85 Tenshi_FRS Southern California 3 06-05-2015 07:01 PM
Running 245/40/18 on 18 x 8.75 +33? raven1231 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 04-06-2015 03:02 AM
Running but going nowhere. VictorKassil Issues | Warranty | Recalls / TSB 60 02-04-2015 07:18 PM
RPM dip with A/C running BunnyRZed Issues | Warranty | Recalls / TSB 31 10-22-2014 09:56 PM
Running low on gas Arctek83 Scion FR-S / Toyota 86 GT86 General Forum 63 04-15-2013 07:35 PM
