Old 06-11-2013, 03:06 PM   #1
BunnyRZed
BunnyRZed's Avatar
Drives: BRZ Limited [37J]
RPM dip with A/C running
Update: TSB Fix Available
Here's the TSB download link for this issue:
Click Here
Anyone notice that when you have the A/C running and come to a stop the RPM would dip and then go back up? Dealer checked said was this was normal and all the new Subaru does it. Any thoughts?
BunnyRZed is offline   Reply With Quote
Old 06-11-2013, 03:08 PM   #2
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
It's not normal if it's severe and this is a documented issue with the twins. I've had the idle dip from about day 1. Bought mine in July '12. It usually goes away once the motor is warmed up, but it's embrassing to have someone in the passenger seat when the car is cold. They always ask if there's something wrong with the car.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 06-11-2013, 03:17 PM   #3
BunnyRZed
BunnyRZed's Avatar
It seems to happen only when the A/C is running and I'm coming to a stop.
Old 06-11-2013, 04:04 PM   #4
NYNOMAD
Drives: BRZ WRB LTD MAN
With the A/C on it's normal.
NYNOMAD is offline   Reply With Quote
Old 06-11-2013, 04:18 PM   #5
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Not a fan of this car with AC on over 90 degree heat.. Too much of a drag to run the AC system.. Probably the main reason i'm going to add more low RPM focused mods to the car to battle this...
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 06-11-2013, 04:23 PM   #6
spyingwind
Drives: White '17 86
The A/C will toggle off if you floor it. Casual driving you shouldn't see or feel the A/C turn off.
If you turn on the A/C and the rear defroster at the same time it dips pretty hard, but then again you shouldn't be doing that. :P
Add an exhaust and most people won't notice a thing.
spyingwind is offline   Reply With Quote
Old 06-11-2013, 05:39 PM   #7
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
normal to me. most vehicles i driven, including family minivan had little RPM dip.
Old 06-11-2013, 06:29 PM   #8
fistpoint
Drives: Supercharged Golf Cart
Same here, coasting to a stop sign/light in gear...when I get to around 8mph or less I put it in neutral and the dip happens.
Only with A/C on, the idle is totally stable without A/C. I do NOT think I am a candidate for the idle issue as that issue happens A/C on or off.
fistpoint is offline   Reply With Quote
Old 06-11-2013, 07:59 PM   #9
BunnyRZed
BunnyRZed's Avatar
Sounds like everyone is saying this is normal when A/C is on, thanks.
Old 06-11-2013, 08:32 PM   #10
Dalers08
Drives: 2001 Audi A4
What happens (in every car) is the A/C pulls a decent amount of electricity to run, so when the engine is turning at idle it is asking the alternator to pull harder to make more power to use the A/C. In older cars or cars with weaker electrical systems (my 90 240 for example) at idle if you roll the windows down the rpm's take a dive.
Dalers08 is offline   Reply With Quote
Old 06-11-2013, 08:42 PM   #11
whtchocla7e
Drives: 2013 FR-S Hot Lava
What other devices run off the alternator in this car? Even though I seem to have everything turned off on the dash/console I still feel like the alternator kicks in constantly. I'd like to turn everything completely off and see if it makes a difference to my idle.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 06-11-2013, 08:55 PM   #12
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I think the load on the engine itself to run the compressor is much more of the problem than the load on the electrical system.
SloS14 is offline   Reply With Quote
Old 06-11-2013, 08:58 PM   #13
Mikem53
Drives: FR-S 6MT
It happens to me too and its not the idle dip issue mentioned above.
only occurs during rpm drop to idle and the AC compressor kicks in
and drops the rpms too low, then it quickly recovers after stumbling
and then is stable..
Only when the engine is not engaged to the trans when coming to a stop.
Not every time.. but happened a few times to me under those conditions..
IMO.. Its a software glitch..
otherwise i find the idle with compressor cycling to be very smooth and
transparent in operation.
mid 90's tomorrow forecasted.. Raven in the hot sun =
Mikem53 is offline   Reply With Quote
Old 06-11-2013, 09:11 PM   #14
Mikem53
Drives: FR-S 6MT
The electric power steering system is quite power consuming at times..
Running low on gas Arctek83 Scion FR-S / Toyota 86 GT86 General Forum 63 04-15-2013 07:35 PM
Anyone running this size? cruzinbill Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-26-2013 09:15 PM
Anyone running a tune? swift996 Mid-Atlantic 9 02-04-2013 10:43 AM
HID for Daylight Running Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 3 09-21-2012 06:47 PM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
