Old 11-27-2015, 01:28 PM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Review || DIF/FRSport replacement seat rail hardware w/ metric bolt head
I had to take out my passenger side last month, and realized that the factory seat rail bolts needs a E10 Torx socket to remove. The head is incredibly easy to strip/round if you have the wrong hardware.
I do plan on installing aftermarket bucket seats in the future, and needed a better solution that minimizes the amount of tools I have with me.
Turns out, one of the vendors on here already has a product to replace the seat rail bolts.
@FRSport.com carries a replacement seat bolt for this car.
The bolt itself is same size/thread as the factory bolt, but uses a larger 14mm bolt head. The included washers will come in handy when I install aftermarket seat rails.
Something worth taking a look at if you fear stripping your OEM seat rail hardware or otherwise take out your seats on a regular basis.
http://www.frsport.com/DIF-10585-Gra..._p_282801.html
-alex
Edit: E10 Torx socket available from FRSport as well: http://www.frsport.com/Lisle-26820-T..._p_281610.html
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
danny_d19 (11-28-2015), FirstWinter (08-25-2018)
Old 11-27-2015, 04:38 PM   #2
FRSport.com
FRSport.com's Avatar
Drives: Scion FR-S Subaru BRZ
Send a message via AIM to FRSport.com
-alex
Thank you for the Review!!
Send me an Email
Bench@frsport.com so we can shoot you some swag!
FRSport.com is offline   Reply With Quote
Old 08-29-2018, 08:43 PM   #3
FirstWinter
Drives: Car
Just wanted to let anybody know with the same issue these bolts from McMaster Carr work as well. OEM bolts thread size & pitch is M10 x 1.25 mm and 28 mm long. The McMaster bolts use a 14 mm hex head bolt which should be less likely to strip.
FirstWinter is offline   Reply With Quote
How to remove seat rail bolt after you've stripped it protpibe DIY (Do-It-Yourself) Guides 33 02-01-2020 02:06 PM
Need Help Unbolting The Seat Rail Bolt hooverbucs14 Scion FR-S / Toyota 86 GT86 General Forum 2 01-09-2015 11:59 AM
Seat rail bolt part number? nalc Cosmetic Modification (Interior/Exterior/Lighting) 5 12-05-2013 10:16 AM
need help unbolt seat rail bolt chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 2 07-01-2013 10:06 AM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
