Old 07-01-2013, 12:24 AM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
need help unbolt seat rail bolt
i'm installing the Arkon gooseneck phone mount which requires the removal of seat rail bolt. For some reason, i just can't loosen the bolt. I used so much force that i stripped the socket that i used. Is there any tricks to loosen the seat rail bolt? Counter clock wise right?
chenshuo is offline   Reply With Quote
Old 07-01-2013, 02:38 AM   #2
Eh-Tee
Drives: 2013 FRS - Asphalt
The bolt comes out with a TORX E10 socket. I ended up stripping the bolt (by using something other than an E10) attempting to install a phone mount as well. I tried using a stripped bolt set, drilling into it, etc. to no avail, so I just gave up. However, the E10 works perfectly on intact bolts. And yes, counter-clockwise to loosen.
Eh-Tee is offline   Reply With Quote
The Following 3 Users Say Thank You to Eh-Tee For This Useful Post:
chenshuo (07-01-2013), enivid (12-18-2015), sidnacious (07-01-2013)
Old 07-01-2013, 10:06 AM   #3
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
ok i guess i have to get the TORX socket.
One related question: when you install the phone mount, our seat rail bolt sits in a groove, how did you put the phone mount base into the groove? do you have a picture that you can show me?
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
Nagisa Auto D-Lock Super Low Seat Rail poormans_LFA Cosmetic Modification (Interior/Exterior/Lighting) 3 11-06-2012 04:35 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
CP Rail on strike. Where is my BRZ/FRS? percyng CANADA 15 05-28-2012 09:17 PM
Is your BRZ shipment going to be on rail in Canada? dorkymork BRZ First-Gen (2012+) — General Topics 1 05-23-2012 04:44 PM
