Old 01-08-2015, 11:02 PM   #1
hooverbucs14
hooverbucs14's Avatar
Drives: Scion FR-S 10 Series
Need Help Unbolting The Seat Rail Bolt
I need help Unbolting the seat rail bolt. But I stripped the bolt. I do own a E10 Torx socket, but my bolt is still stripped. Can anybody explain it to me please? Thank you!
hooverbucs14 is offline   Reply With Quote
Old 01-08-2015, 11:39 PM   #2
jonzhuxD
Drives: Ultramarine FR-S
I had this problem too, I tried to cut a slot into the bolt head and use a flathead socket and an impact to get it out but this ended up destroying the bolt head!
I ended up carefully drilling into the bolt and used a screw extractor to get it out. Luckily it came out without any problems
Good luck with yours!
jonzhuxD is offline   Reply With Quote
Old 01-09-2015, 11:59 AM   #3
hooverbucs14
Thanks! I guess I will try this method!
help me, interior, mods, seats, stripped
How to remove seat rail bolt after you've stripped it protpibe DIY (Do-It-Yourself) Guides 33 02-01-2020 02:06 PM
Remove seat rail bolts existensil Cosmetic Modification (Interior/Exterior/Lighting) 12 06-09-2014 04:20 PM
Seat rail bolt part number? nalc Cosmetic Modification (Interior/Exterior/Lighting) 5 12-05-2013 10:16 AM
need help unbolt seat rail bolt chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 2 07-01-2013 10:06 AM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
