Old 11-25-2015, 11:32 PM   #1
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Steering column gauge option?
I've been searching and haven't found a single option for the steering column like on the Subaru Impreza STI/WRX.
I just want a single gauge on the column that looks close to factory.
Anyone?
HuntingtonFRS is offline   Reply With Quote
Old 11-25-2015, 11:50 PM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Someone can and will correct me if (read: when) I am wrong, but I think people usually just use a universal pod/mount for applications like that.
Sent from my Nexus 5X using Tapatalk
Bobblehead is offline   Reply With Quote
Old 11-26-2015, 02:21 AM   #3
ryoma
ryoma's Avatar
http://perrinperformance.com/i-13323...gauge-pod.html
Old 11-26-2015, 11:12 AM   #4
HuntingtonFRS
Originally Posted by ryoma View Post
It's not bad, but I would prefer a single mount. I guess you could just not mount both?
I did come across this custom made option:
http://www.ortizcustompods.com/scion.html
Old 11-26-2015, 03:12 PM   #5
ryoma
ryoma's Avatar
the first cluster gauge pod looks cool.
Old 11-26-2015, 06:30 PM   #6
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I'm using a "Scan Gauge X Gauge" just plugs into the ECU port. You can choose just about anything you want. I'm showing oil temp, water temp, and automatic tranny temp.
Lunatic is offline   Reply With Quote
Steering Column Creak michaelahess Issues | Warranty | Recalls / TSB 12 06-27-2018 01:14 AM
Ticking/Rattling coming from steering column/gauge cluster Imprezzave Issues | Warranty | Recalls / TSB 24 09-17-2016 09:38 AM
Steering Column Gauge Pod options TmP Cosmetic Modification (Interior/Exterior/Lighting) 3 05-16-2014 03:07 PM
Steering Column Cover Pablitomarrero Cosmetic Modification (Interior/Exterior/Lighting) 6 11-23-2013 11:29 AM
WTB: Steering Column Cover (top one) Jamifra Interior Parts (Incl. Lighting) 6 11-27-2012 09:20 AM
