Old 11-21-2013, 08:57 PM   #1
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Steering Column Cover
Does anybody have any idea How to do this? I already removed the two screws behind the wheel and removed the bottom part but for the life of me I cant figure out how to remove the damn little leather rag thats holding on to the top half. I know its a clip... but I dont understand it and I think im starting to break it. Help
Pablitomarrero is offline   Reply With Quote
Old 11-21-2013, 10:18 PM   #2
Gen
Drives: Scion FR-S
If memory serves... remove the cluster hood (1 screw). After that there are two screws for the gauges. Remove gauges and you should gain access to what you need.
Gen is offline   Reply With Quote
Old 11-21-2013, 10:22 PM   #3
Pablitomarrero
wow, that is the worst steering column cover to remove that ive ever seen! I just wanted to drill three holes into it... maybe i can manipulate enough to so what i want
Old 11-21-2013, 10:26 PM   #4
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
i was trying to do the same thing to drill in and mount my scan gauge, couldn't figure it out, said F it and mounted the gauge with some 3M automotive mounting double-sided tape.
smbstyle is offline   Reply With Quote
Old 11-21-2013, 10:36 PM   #5
Pablitomarrero
Lol yes I will not dissaseble the dash to drill three holes! I gotta have some 3M lying around..
Old 11-21-2013, 10:39 PM   #6
smbstyle
smbstyle's Avatar
If you cant find it, any auto parts store will have it in the body shop/trim area of it, 3M automotive trim bonding tape I believe....
Old 11-23-2013, 11:29 AM   #7
Pablitomarrero
I managed to remove it! Just wedge you fingers in between the plastic plate and it will eventually clip out. Apply preassure... Its pretty flexible so it wont break (which was my main worry)
Steering Column Creak michaelahess Issues | Warranty | Recalls / TSB 12 06-27-2018 01:14 AM
Ticking/Rattling coming from steering column/gauge cluster Imprezzave Issues | Warranty | Recalls / TSB 24 09-17-2016 09:38 AM
soft steering wheel cover cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 3 07-29-2013 09:07 AM
WTB: Steering Column Cover (top one) Jamifra Interior Parts (Incl. Lighting) 6 11-27-2012 09:20 AM
How to remove steering column trim? Gen Electronics | Audio | NAV | Infotainment 1 10-29-2012 12:36 AM
