Drives: 86
Issue after changing Rear Rotors
Hey guys:
I just changed my stock rear rotors to DBA T3 slotted rotors. I found my hand brake did not work effectively after changing rotors. I need to pull it up very very high in order to park on the hill... Someone said I need to adjust the park shoe while others say I need to bring the car up to 30, pull up on the brake hard and let the car stop... Btw, I cleaned the new rotors very carefully with brake cleaner. Anyone had the same experience? Appreciate any imformation
Drives: gt86
Sounds like the mechanic who did it forgot something.
Drives: Da-Big Banana
OP your parking brake needs to be adjusted.
Put the stock rotors back on...Vehicle Repaired haha
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
[ame="https://www.youtube.com/watch?v=JePOTERmApw"]How To Adjust Your Drum Brakes - YouTube[/ame]
I don't think the dust plate has that slot in it, so you'll have to line up that extra hole in the rotor with the adjuster to get a flathead screwdriver on it. adjust it until it drags and then back off a bit. |
Drives: Scion FR-S (Hot Lava)
I've had this problem for over a year now! Tried adjusting it with little success.. But I'll give it another go in the spring.
My problem was that I never knew which way to adjust the cog. Does it tighten to the left or right? As in should I use the left hand or right hand rule? |
| FS: New Centric Rear Rotors | Hanakuso | Brakes, Suspension, Chassis | 10 | 10-31-2015 06:36 PM |
| Different brand rear fluid changing torque bias? | zooki | Engine, Exhaust, Transmission | 1 | 09-06-2015 10:13 PM |
| 114.3 stock rear rotors? | Celigts | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 03-09-2015 07:00 AM |
| Important: DBA Rear Rotors (BRZ/FR-S) | FRS2000 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 07-17-2013 08:08 PM |
| [WA] FS: GTS Front AND Rear Rotors | stevo_12v | Australia Classifieds | 0 | 01-04-2013 08:43 AM |
