Old 11-25-2012, 09:19 PM   #1
FRS2000
FRS2000's Avatar
Drives: whiteout frs
Important: DBA Rear Rotors (BRZ/FR-S)
Be advised if you ordered DBA rear rotors or plan on doing so you'll need
to confirm you have the correct rear rotors for BRZ/FR-S.
I received non-vented 4000 series rotors (42659S)...these are wrong for FR-S
For the 4000 series, you'll need DBA42663S...these are vented ones for FR-S.
They were just released by DBA.
Note: BRZ comes with either vented(limited) or non-vented(premium) rears
[COLOR=#3A352A!important]Toyota 86GTS
Toyota GT86
SCION FR-S
Subaru BRZ Premium
Subaru BRZ Sport
[/COLOR]
Rear Disc Brake Rotors NOW available
Part Details:
DBA2663S - Street Series T2 slotted
DBA42663 - HD 4000 series standard finish
DBA42663S - CLUBSPEC 4000 series T3 slotted
DBA42663XS - CLUBSPEC 4000 series XS
FRS2000 is offline   Reply With Quote
Old 11-27-2012, 06:14 PM   #2
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
I was going to say these have not been out until very recently.
We run the fronts on our car and soon the rears. DBA is top notch!
FT-86 SpeedFactory is offline   Reply With Quote
Old 11-28-2012, 06:21 PM   #3
86drift
86drift's Avatar
Drives: Toyota 86 GT
The 42659S are rear discs for the lower spec cars delivered in Aus, Jap, etc.
4648S is the part number for the lower spec front discs.
I received non-vented 4000 series rotors (42659S)...these are wrong.
For the 4000 series, you'll need DBA42663S...these are vented ones.
Toyota GT86
SCION FR-S
Subaru BRZ Premium
Subaru BRZ Sport
[/COLOR]
Part Details:
86drift is offline   Reply With Quote
Old 12-03-2012, 10:35 AM   #4
FT-86 SpeedFactory
BTW, I followed up with DBA and the rears will not be ready until March for the USA Market.
Old 12-04-2012, 11:16 PM   #5
FRS2000
FRS2000's Avatar
BRZ/FR-S Rear Rotors
My understanding...
US Limited BRZ has vented rear rotors
US Premium BRZ has non-vented rotors
US FR-S has vented rear rotors
Old 07-15-2013, 03:38 PM   #6
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Rallysport Direct will be stocking the DBA42663S - CLUBSPEC 4000 series T3 slotted in a couple of weeks
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 07-15-2013, 04:39 PM   #7
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
My understanding...
All US cars have the same brake hardware.
Admiral Ballsy is offline   Reply With Quote
Old 07-15-2013, 05:31 PM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
If you check the DBA book it lists different rotors for the Limited and Premium. I ordered a full set for my limited and they were ALL WRONG. The rears were not vented and the fronts were about an inch too small.
The DB in DBA stands for Don't Bother.
Oh, and I'll also add that the vents in the front rotors were radial. They weren't the "Kangaroo Paw" that DBA promotes.
Old 07-15-2013, 09:02 PM   #9
tonystewart
I must be lucky, Rallysport Direct took care of my fronts.
Old 07-15-2013, 09:59 PM   #10
Admiral Ballsy
Shorter of breath
The smaller front/solid rear setup is used on the low-content cars in some markets (Australia being one) - the ones with the 16" wheels.
Old 07-15-2013, 10:10 PM   #11
Draco-REX
Corner Junkie
Draco-REX's Avatar
Unfortunately, they are marketed to the US market as the appropriate parts in both their published jobber catalog and our in-house EPC. Needless to say, I was peeved when I wasted an afternoon due to this. I was going to keep a matched set of track pads and rotors, but instead I just sent them all back and re-bedded my street pads on my stock blanks.
Old 07-16-2013, 12:43 AM   #12
FRS2000
FRS2000's Avatar
DBA rears
thanks for the heads up on rallysport direct... been waiting awhile for the vented rears for my frs.
Old 07-16-2013, 12:46 AM   #13
FRS2000
FRS2000's Avatar
** I verified that the Brz has different rear rotors available between premium and limited models. I checked both at the dealership. I haven't confirmed the fronts though.
FYI: I contacted DBA directly in Australia... they have good customer service.
Old 07-16-2013, 08:35 AM   #14
tonystewart
Horsepower Direct has them as well
DBA T3 rotors fitted AVOturboworld Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-16-2013 02:28 PM
Color, how important is it to you? Iixii BRZ First-Gen (2012+) — General Topics 63 11-09-2012 10:25 AM
OptionJDM - DBA Rotors OptionJDM Brakes, Suspension, Chassis 6 07-21-2012 11:50 AM
StopTech Slotted Brake Rotors (Front/Rear) for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 0 07-13-2012 10:58 AM
How important is an LSD on this car? colHolm Scion FR-S / Toyota 86 GT86 General Forum 92 05-13-2011 05:53 PM
