Old 03-08-2015, 03:41 PM   #1
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
114.3 stock rear rotors?
Do they make 114.3 rotors that'll fit on our rear rotors?
Basically I'm looking to do the hub conversion and cannot find a solution...
They make rotors that are 114.3 obviously but apparently they require new brakes and that's not in the cards right now ...
Basically I'm looking for SAME SPEC Rotors as our rear but are 5x114.3 instead of the stock 5x100.
Any advice?
Celigts is offline   Reply With Quote
Old 03-08-2015, 03:53 PM   #2
swarb
It is not simply just swapping rotors, you need to swap HUBS in addition. You can buy conversion hubs and drill new holes in the rotors. The other solution is getting sti parts or z32 parts. If you can't afford new brakes, you can't afford the hub conversion. At that point just get conversion spacers.
The Following User Says Thank You to swarb For This Useful Post:
Celigts (03-08-2015)
Old 03-08-2015, 04:49 PM   #3
Celigts
Celigts's Avatar
I can afford it ... just don't know enough about brakes to pick the right ones. I'm not there in my build yet
I bought the hub conversion rears ... Any way i can avoid re-drilling? They don't make a 5x100 rotor for our cars that also have holes for 5x114.3?? Hard to believe We can't get BOTH!
Bought 15mm project kics conversion for the front ...
Old 03-08-2015, 05:18 PM   #4
swarb
I remember reading about a rotor that was the same size in 114, you just have to search for it(was it dba rotors?), many companies will find or drill you a set for your application. Or measure/find the specs of the stock size and call someone or open up a application list with specs from a rotor company.
Old 03-08-2015, 06:04 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Any advice?
Z32 (aka 300zx) rears are the same size discs in 5x114.3
Old 03-08-2015, 06:41 PM   #6
Celigts
Celigts's Avatar
Anyone confirm this??? I'm going to Google it now.
Old 03-08-2015, 07:23 PM   #7
finch1750
finch1750's Avatar
Its been discussed in the z32 caliper swap thread. Search something like "my $600 bbk"
Old 03-08-2015, 07:35 PM   #8
Celigts
Celigts's Avatar
I saw that the z31 87-89 says it's 290x18mm
Which is the same thing as the stock FRS rear rotors ...
Does this mean it works?
I'll see if i can locate the z32 caliper swap thread.
Old 03-08-2015, 07:41 PM   #9
Celigts
Celigts's Avatar
Found this
http://www.nicoclub.com/archives/nis...r-frs-brz.html
But this is a write up for the FRONT.
Our Front rotors are different than our rears, so this won't work right?
Thanks,
Old 03-08-2015, 07:44 PM   #10
finch1750
finch1750's Avatar
Found this
Thanks,
The fronts are different, but the rears are the same. Its discussed when talking about brake bias to ensure it remained OK compared to stock.
Old 03-08-2015, 07:51 PM   #11
Celigts
Celigts's Avatar
Rotors:
Rotor Specs: Legacy GT front rotors are 316mm in diameter by 30mm in width. Stock BRZ/FRS rotors are 294mm in diameter and 24mm in width. OEM Legacy GT rotors are 22 lbs while BRZ rotors are 17 lbs.
he used legacy rotors in this and they are fronts only.
what do i look for when comparing stock rotors to ensure the brakes will fit?
stock oem rear frs rotors:
I've found that 87-89 z31 (300zx) rotors are:
5x114.3
290x18mm
What else do I need to make sure works for the rotors?
Remember I'm going to be using the Subaru rear hubs.
Old 03-08-2015, 08:00 PM   #12
Celigts
Celigts's Avatar
Wait...This confused me...
You're saying I can use the z32 rotor on the REAR and retain the same STOCK frs brakes?
Old 03-08-2015, 09:26 PM   #13
Celigts
Celigts's Avatar
Just checked with a local auto parts store...the z31 rotor and z32 rotors will not fit the hub. They are too big
Back to Square one.
Old 03-08-2015, 10:35 PM   #14
finch1750
finch1750's Avatar
Back to Square one.
What size is the hub on the z32?
Removing rear brake rotors? Kuzuri Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-18-2015 09:08 PM
WTB: Stock pads and rotors tawheed Want-To-Buy Requests 0 08-09-2014 03:26 PM
Important: DBA Rear Rotors (BRZ/FR-S) FRS2000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-17-2013 08:08 PM
Selling stock FRS Springs/Struts + Stock Pads + Rotors 6k on all! NickFRS Brakes, Suspension, Chassis 6 03-14-2013 01:38 AM
[WA] FS: GTS Front AND Rear Rotors stevo_12v Australia Classifieds 0 01-04-2013 08:43 AM
