Old 11-14-2015, 03:18 AM   #1
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Ecu Tuning after Final Drive Swap
I have no idea about ecu tuning after Final Drive swap.
I know after FD swap the engine load change in each gear and i know AFR and timing tables have various value in each rpm and load .
it seems ecu tuning after FD swap is meaningless but i like to know more information about this subject.
let me know if i think wrong : in dyno tuning the engine pull constant load and the tuner just adjust afr/timing/cam in one value of load/rpm , do they fill other value of tables with multiplying in an constant (for each load)?
please let me know a better view about ecu tuning in various loads.
Toyota86.ir is offline   Reply With Quote
Old 11-14-2015, 05:31 AM   #2
steve99
the car derives speed ino from wheel sensors so finial drive swap want effect speed reading.
it will however throw od the gear display in dash and you may need to alter the ecu to compensate tables are "gear determination thresholds"
elsewise should be ok ecu use derived engine loads to determine timing fueling cam timing ect not speed .or gear
Old 11-14-2015, 06:50 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Don't confuse engine load with the load calculation that the ECU uses. The engine calculations are based on grams of air per revolution, that won't change by changing a FD.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-14-2015, 10:21 AM   #4
Toyota86.ir
the gear indicator is not my problem.
In my mind the load is the force needed to rotate the wheels in a specific rpm , it means the load increase when the car weight increase or when the car goes to uphill.
i want to know what happen to ecu in these various loads?
do ecu change AFR/timing/cam in uphill/downhill?
it seems ecu will retard timing in uphill (high load on engine) , if ecu do that it should advance timing in downhill. if ecu change timing in various loads then it should change the timing after FD swap.
Old 11-14-2015, 01:44 PM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Re-read what I said. Loading the engine and the load calculations for the engine are different. I explained what load means as far as the columns mean in the tables. It's not what you said.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-14-2015, 01:57 PM   #6
Toyota86.ir
Ok
You mean the load (higher/lower FD) has no effect on ecu.
Old 11-14-2015, 03:17 PM   #7
steve99
Ok
no real difference to ecu it will sort it out its like driving in 4th as opposed to 5th..
see here re load calculation
http://www.romraider.com/forum/viewtopic.php?t=615
http://www.romraider.com/forum/viewt...hp?f=15&t=8218
Old 11-14-2015, 11:46 PM   #8
Toyota86.ir
Thank you , very good link
Old 11-15-2015, 01:45 PM   #9
KoolBRZ
KoolBRZ's Avatar
With an AT, torque is needed to pull away from a stop. An MT can just rev and slip the clutch, but an AT has to have the torque to pull away without bogging. When you switch to a FD that is easier on the engine, you can tune for higher revving with less torque down low, since you don't need as much torque now. You are right that a different tune can get more out of the car after a FD swap. You could change your requested torque B table to use an MT table and get a more linear throttle response. You can shift the torque needed at launch to higher up in the mid-range with the right tuning.
If I say yes, will that make you think I understand?
Old 11-17-2015, 11:43 AM   #10
Toyota86.ir
good news if it's possible to shift the power to higher rev.
do tuners shift power band with cam tuning ?
Old 11-17-2015, 11:58 AM   #11
mrk1
Drives: Sterling BRZ Ltd
I have swapped my FD numerous times with no mention to the tuner, only need would be for the gear display and I never use it.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 11-17-2015, 01:48 PM   #12
KoolBRZ
KoolBRZ's Avatar
Looks like you'll have to talk to Mike the tuner about that. AT's do need more torque at launch than MT's, so the electric throttle mapping is different than the MT's.
Old 11-17-2015, 02:35 PM   #13
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
Tuners could. But I have no idea what most "tuners" do.
Variable cam timing allows one to control overlap. More or less overlap can move your peaks a little to the right or left, depending on what you're trying to achieve. But the cams themselves are the ultimate deciding factor for powerband rpm.
Scott@HKSUSA is offline   Reply With Quote
Old 11-17-2015, 02:35 PM   #14
Toyota86.ir
yes i will send an email to Mike.
Mike is great , he is so busy these days.
i will do that .
WTB: 4.56 Final Drive jaorocks1 Want-To-Buy Requests 0 11-04-2015 07:36 PM
3.7 Final Drive GsxrMe Engine, Exhaust, Transmission 9 09-28-2015 07:55 AM
final gear swap on AT xsnapshot Engine, Exhaust, Transmission 2 02-19-2015 07:25 PM
My final gear swap project PantsDants Engine, Exhaust, Transmission 120 06-29-2014 07:24 PM
Tuning adjustments for different final drive ratios? PantsDants Software Tuning 9 01-29-2014 03:18 PM
