Old 01-22-2014, 01:31 AM   #1
PantsDants
Drives: Scion FR-S A/T, Whiteout
Tuning adjustments for different final drive ratios?
So I've been running my 4.88 FD on my 6AT for a few months now and I have to say I'm really enjoying it. Shifts in auto mode are still dead on, speedo still works right, and the bump in acceleration was definitely worth the effort.
Enter tuning. I have an OFT and the new 1.5 map is great, but I can't help but wonder if there are adjustments to be made to the tune to take better advantage of the shorter final drive. This stems from the fact that there are unique stock roms for cars in the EU that have different FD ratios; why would they bother with that if there weren't any mapping changes?
Any ideas guys? Are there any parameters in the map to be tweaked to take advantage of a different FD ratio?
PantsDants is offline   Reply With Quote
Old 01-22-2014, 07:14 AM   #2
8686
8686's Avatar
Drives: 86
Interested to discover more about this as I have the 4.55 FD
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 01-22-2014, 11:07 AM   #3
arghx7
Drives: car
Has anyone done a comparison between the ROMs for different final drives?
arghx7 is offline   Reply With Quote
Old 01-22-2014, 04:24 PM   #4
PantsDants
I don't have access to those roms, but I know someone who does... *cough* @shiv@vishnu *cough*
Old 01-22-2014, 05:42 PM   #5
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Everyone has access to said roms thanks to Shiv. I know I saw the table in RomRaider to edit the gear indicator for manual transmissions. I am sure there is more, but some of it might have to be defined and unfortunately this requires hacking at the bin files to determine what things do.
Luckrider is offline   Reply With Quote
Old 01-22-2014, 08:21 PM   #6
PantsDants
The stock roms are in there too? Hmm... need to check my files again.
Old 01-22-2014, 08:23 PM   #7
Luckrider
Luckrider's Avatar
Each set of tuned ROMs contains a stock rom. Just download the 1.42b and you will have every stock ROM that Shiv has.
Old 01-22-2014, 08:59 PM   #8
jamesm
You'll want to adjust the gear limits so that your gear indicator will be correct.
Old 01-22-2014, 09:37 PM   #9
Luckrider
Luckrider's Avatar
I'm not sure how the twins work, but I wouldn't think gear display is a calculation with the autos. Then again, it is much easier for a manufacturer to write one set of code and calibrate it for the different setups.
Old 01-29-2014, 03:18 PM   #10
SpeedR
First86 / boat thief
Drives: MKIV Supra
Originally Posted by L8Apex View Post
I have the same 4.88 FD setup as PantsDants in my AT6 (actually followed his instructions to duplicate everything, much thanks!!) and I'm loving it. I'm also curious if the tune can be optimized for the higher final drive.
From what I can see the AT has a speed sensor on the trans output shaft in addition to obtaining the VSS (vehicle speed sensor) signal from wheel sensors. My theory is it uses the speed sensor on the trans to shift the AT at correct shift points, and wheel speed sensors for dash cluster speedo and stability control stuff. The separate speed sensors allow shift logic, speedo, and VSC to all function accurately in spite of the FD change.
Gear indicator on the AT comes from the TCM which uses the trans-mounted speed sensor so it should be unaffected by FD changes on the AT6. But current gear is calculated in the MT6, probably from wheel sensors, and might require an ECU change to fix this, not sure.
Engine tuning itself seems independent from gear ratios so I'm guessing there's no difference in actual tune, but I'm hoping someone can confirm. (Shiv?) I'm not familiar enough with the tables yet.
Thanks for the info.
Can any one confirm this?
SpeedR is offline   Reply With Quote
CUSCO 4.55 FINAL DRIVE installed. Racecomp Engineering Engine, Exhaust, Transmission 488 06-17-2018 12:14 AM
Final Drive Discussion JimmyMac Engine, Exhaust, Transmission 118 08-07-2017 10:18 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 04:06 AM
Anyone w/ 3.727/3.909 Final Drive Post Boost? Staf00 Engine, Exhaust, Transmission 12 05-02-2013 08:38 PM
