Old 08-26-2013, 04:40 AM   #1
PantsDants
Drives: Scion FR-S A/T, Whiteout
My final gear swap project
EDIT, 10/17:
For the list of parts and relative costs of this swap: http://www.ft86club.com/forums/showthread.php?p=1275527
(By the way, everything actually worked!)
I read the thread about the Cusco 4.556 final drive gear kit and how it is a god-send for those of us who intend to stay N/A. What I took from that was that the Cusco kit was simply re-boxed Toyota parts with an insane markup. So that got me thinking: Why don't I just source my own parts? And why not go bigger (shorter)? So here's the fruit of a few weeks of research hitting various forums and vendors!
According to @Jeff Lange, the rear differential carrier out of an IS300 is a direct swap into our cars, and the T2 Torsen LSD inside it is identical to what our cars have. So my first step in this project was to source one, because I liked the idea of minimizing my time without my car, with the bonus of having two fully functional carriers in the end. You could definitely just swap the ring and pinion into your stock differential, but since I'm kind of being a pioneer (read: guinea pig) here, I decided I didn't want to risk having everything apart and have something not fit.
There are two versions that come with an LSD and there are two that are open differentials. The ones we want (LSD) are marked with axle code stickers M98 and M85. The M98 is from an automatic IS300, and is a 3.9 final drive ratio. The M85 is from the manual and is 3.7. I managed to source a basically brand new M98 from a major auto recycling company out here.
With that out of the way, I needed to figure out what ring and pinion kits are actually compatible with this carrier. After trolling various IS forums, I found that ring and pinion sets meant for a North American MK3 Supra (8" or 205mm ring diameter) will fit, but the pinion seal will most likely not. (The pinion seal for the IS300 from Toyota is 90311-38070 and is like $9 online.)
Spence over at http://weirperformance.com/ sells ring and pinion kits specifically for the Mark 3 Supra in a wide range of ratios, including the 4.556, for $225. I spoke with him on the phone specifically about using one of his kits in the IS300 carrier, and he told me that he's had a few IS guys buy from him for this purpose and no one has called back to say the parts didn't fit. He also sells installation kits, which include bearings, adjustment shims, solid spacer, etc. The price on that will vary depending on exactly what you need. At the very least, you'll need the shims, pinion nut, and spacer, as well as the IS300 pinion seal but he doesn't sell that. There's probably something else I'm forgetting here but he'll hook you up.
I haven't ordered my gear kit yet simply because A) I'm heading out on a road trip in a week and B) I haven't quite decided on the gear ratio I want to run. That said, I THINK I'm leaning towards a 4.88 or 5.29 final drive.
"THAT'S CRAY HOLY CRAP YOU'LL BE CRUISING AT 8K RPMS" you might say. However, my car is an automatic. The difference in 6th gear between the automatic and manual in this car is huge: .582 on the auto, and .767 on the manual. Using a gear calculator app, (I used this one: http://pw1.netcom.com/~sgalaba/mph.htm) I figured out that with stock tire sizes and a final drive ratio of 5.29, I'll be running at 2500 rpm at 60 mph. I am more than willing to live with that. I even tried holding my car in 4th at freeway speeds just to see what the sound levels were like around those revs and didn't detect any audible difference. Granted, I've not done anything with my exhaust yet, so I may live to regret this decision, but I feel like for the money I'll be putting into this project, I may as well go big.
For the price breakdown, here's what I'm looking at:
  • $400 for the IS300 carrier (they can be had for as low as ~$250 from a scrap yard/eBay, but this was basically brand new so I jumped on it). Again this is optional.
  • $225 for the ring and pinion set
  • ~$150 for the installation bits (this is just an estimate really; the full installation kit they sell is ~$300 but I don't need the expensive parts, which are the bearings)
So rounding up, that's around $800 in parts, about a $200 or more savings against the Cusco kit, BUT, that's with buying a whole other carrier.
If you're just swapping the parts into your own carrier, worst case scenario, you're looking at around $500 if you need the full installation kit, ~$400 if you only need the essential bits. That's a helluva deal compared to the Cusco kit.
For labor, I was quoted $400 for the ring and pinion install, and about $250 for swapping the carrier into my car. So the grand total for me is going to be around $1500. Again, this would be even cheaper if you don't buy a separate carrier.
Questions? Comments? Concerns? Please note that I have not actually done this yet; I plan to order my ring and pinion after I get back in a couple weeks and get the install done ASAP after that. I will update this thread with my progress, positive or negative, and any pertinent details I can glean from the shop as they do the install.
Edit, 8/26: Full list of installation parts (everything besides ring and pinion) can be had here: http://www.ft86club.com/forums/showp...5&postcount=45
PantsDants is offline   Reply With Quote
The Following 11 Users Say Thank You to PantsDants For This Useful Post:
37 (08-26-2013), Ammonia (10-04-2013), CARNZ (10-31-2013), flippy (08-26-2013), Fly Guy (04-22-2014), JimmyMac (08-26-2013), leon78 (08-28-2013), makesdrivingfunagain (08-08-2015), misooscar (08-26-2015), Wayno (03-30-2016), zoomzoomers (08-27-2013)
Old 08-26-2013, 04:51 AM   #2
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
You should post some of this info in the final drive thread. I've seen the Cusco 4.56 for under $900 here in the US. But I like your deal much better. Hmmmm maybe they gave automatics that ratio to keep them slower than manuals... hehe... just kidding...?? Thanks for the info.
JimmyMac is offline   Reply With Quote
Old 08-26-2013, 05:01 AM   #3
PantsDants
Hahaha, my guess was fuel economy, but you're probably right.
I did mention Weir Performance in that thread. Spence sells the shims in his installation kit. I can throw down some more knowledge in that thread, but I'd feel more comfortable AFTER I do my install and verify I'm not full of crap.
The Following User Says Thank You to PantsDants For This Useful Post:
Anthony (08-26-2013)
Old 08-26-2013, 06:13 AM   #4
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Alright, I'm confused. Where did you get the 4.88 and 5.29 numbers from? Is that what the IS300's 3.7 and 3.9 equate to in our cars?
Level 1 Noob
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 08-26-2013, 10:40 AM   #5
DoctorNick
DoctorNick's Avatar
Drives: '13 BRZ
Great legwork! I was >hours< away from ordering the Cusco kit! (I still might do it but this is great research).
DoctorNick is offline   Reply With Quote
Old 08-26-2013, 11:08 AM   #6
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Well looks like we've been thinking the same thing in part. I got in touch with Spence a couple of weeks ago and am ordering my 4.56 final drive kit from him today with a solid pinion spacer. All of it shipped for under $350. Granted I still have to get shims, pinion bearing, and pinion seal, but still way better than paying the ridiculous mark up on the Cusco rebranded parts.
Dustin is offline   Reply With Quote
Old 08-26-2013, 11:34 AM   #7
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
very much subscribed
448hpsti is offline   Reply With Quote
Old 08-26-2013, 12:56 PM   #8
PantsDants
Level 1 Noob
4.88 and 5.29 are final gear ratios that Weir Performance offers on their Supra ring and pinion kits; it'll make sense if you check out their site, they have a wide variety of final drive ratios available. The ratio is based on the number of teeth on the ring gear divided by the number of teeth on the pinion. So basically, they're just gears with the same dimensions as our ring and pinion but varying numbers of gear teeth.
Old 08-26-2013, 01:00 PM   #9
Anthony
Weight Nazi
Anthony's Avatar
Oh. Yeah, I completely miss understood you then. I thought these were IS300 gears. But I guess you were just talking about IS300 LSDs?
So what exactly would I need to buy to make a Supra 4.88 work in my car? Explain it to me like I'm retarded because, well...
Old 08-26-2013, 01:01 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Level 1 Noob
No. He is swapping the ring and pinion gear so the 3.7 and 3.9 ratios that come from the factory on the IS300 didn't really matter to him. With his new ring and pinion he will have a 4.88 or 5.29.
The Following User Says Thank You to King Tut For This Useful Post:
PantsDants (08-26-2013)
Old 08-26-2013, 01:02 PM   #11
PantsDants
Just curious, why didn't you buy the shims and pinion bearing from him as well? Markup? He also told me to replace the pinion nut, FWIW.
mswhong (09-03-2013)
Old 08-26-2013, 01:23 PM   #12
PantsDants
The IS300 part of this equation is actually unnecessary to get this done. Theoretically, you can just swap one of these ring and pinion kits into your FR-S/BRZ carrier and be done with it. Again, theoretically. I didn't want to give my car to a diff shop for a few days and have them take my carrier apart and realize something was missing or wouldn't fit. That's why I got the IS300 carrier, so that they could install the ring and pinion in that without taking my car apart, and then when that was done, swap the entire carrier into my car.
Old 08-26-2013, 01:25 PM   #13
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
So, for the FI guys, would the IS300 carrier be a direct swap FD and all, so we can run the auto LSD and get down to a 3.9 FD without any other changes?
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 08-26-2013, 01:25 PM   #14
Anthony
Weight Nazi
Anthony's Avatar
So...
- Ring
- Pinion
- Shim
- Carrier if you don't want down time
That's it? I don't care about down time, so could I just buy the 4.88 ring and pinion, find a matching shim, and go to town?
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Final Fantasy jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 66 08-25-2013 11:31 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 01:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 09:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
