Old 11-04-2015, 11:18 AM   #1
stevesnj
stevesnj's Avatar
OEM intake resonator mod idea
I want to remove the airbox resonator but utilize the resonator hole and connect tubing to it and duct it passenger side for more fresh air intake. Anyone see any cons doing this? It's a small hole but a little more air with a K&N drop in filter should help. Just wondering if this would create turbulence inside the box entry and hinder airflow altogether. Just an idea.
My 2016 Build thread
Old 11-04-2015, 11:39 AM   #2
wparsons
wparsons's Avatar
Depending on the velocities and pressures, you could actually end up with air leaving the airbox through that hole instead of sucking more in.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Cole (11-04-2015), stevesnj (11-04-2015)
Old 11-04-2015, 11:46 AM   #3
fang_gt86
FR Noob
fang_gt86's Avatar
My wildest guess is that it'll create a turbulence within the box. This may ruin the smooth airflow that comes only from the front. A lot of air means nothing if it doesn't flow smoothly.
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 11-04-2015, 11:51 AM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I think this is a waste of time as you pull cold air in from the front bumper already.
Old 11-04-2015, 12:04 PM   #5
stevesnj
stevesnj's Avatar
I am aware
Old 11-04-2015, 12:06 PM   #6
stevesnj
stevesnj's Avatar
Will removing the resonator effect anything? is it a sound resonator or airflow resonator?
Old 11-04-2015, 12:24 PM   #7
wparsons
wparsons's Avatar
http://www.ft86club.com/forums/showp...&postcount=295
flickr
Old 11-04-2015, 01:57 PM   #8
Unlike the sound tube this is not something I would second guess the design engineers on.
Cole (11-05-2015), ddevl_86 (03-30-2021), humfrz (11-05-2015), jawn (11-04-2015), stevesnj (11-04-2015), wparsons (11-05-2015)
Old 11-04-2015, 03:16 PM   #9
stevesnj
stevesnj's Avatar
So after a few hours of research it seems removing the resonators, any or all 4 is not a good idea. If you have a CAI without a tune it seems there is no effect other than more intake noise. Anyway To keep a stable airflow through the OEM velocity stack (scoop) is designed to keep "air reversion" from happening, the resonators are key to this process.. Also the MAF is looking for a stock airstream at a certain temp, pressure and volume. A CAI with a tune specific for the CAI should be more effective. Keeping a consistent airflow before and after the airbox seems most important. So since i'm not going to be tuning my car for a long while it seems a simple K&N filter will help with a more consistent flow of air, pressure and intake temps without inducing unwanted turbulence. At least this is what I think this all means..lol
Sources;
What do air intake resonators do?
Has anyone deleted the resonator in the stock airbox?
The Following User Says Thank You to stevesnj For This Useful Post:
Old 11-04-2015, 04:19 PM   #10
Teseo
Drives: frs
So the case is over?
Teseo is online now   Reply With Quote
Old 11-04-2015, 04:40 PM   #11
stevesnj
stevesnj's Avatar
YES finally..lol at least for me.
Old 11-04-2015, 04:45 PM   #12
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Nice. Wondered this myself. It's ugly, but does its job. Good to know.
Old 11-04-2015, 04:52 PM   #13
stevesnj
stevesnj's Avatar
Anyone know if the TRD intake does or does not use the resonators? By the pics I see the TRD eliminates all but the velocity stack resonators. Maybe why it is so big compared to stock. Seems expensive but engineered perfect to the engine.
Old 11-04-2015, 08:44 PM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
It's big by simple principle. Bigger area of filter = less pressure needed/less restriction to air flow divided over that area. But imho gains are a bit insufficient for cost.
The Following User Says Thank You to churchx For This Useful Post:
Intake Tube - Is the resonator necessary? Perrin, Mishimoto, et al.... Chad_W Engine, Exhaust, Transmission 25 07-21-2015 12:37 PM
Intake resonator removal? ls1ac BRZ First-Gen (2012+) — General Topics 7 04-06-2015 02:54 PM
Intake resonator?? DIE1000DEATHS Engine, Exhaust, Transmission 16 12-03-2014 09:17 PM
Intake resonator delete. mid_life_crisis Engine, Exhaust, Transmission 2 09-12-2013 10:14 PM
Stock intake resonator delete Aaron_blatherwick Engine, Exhaust, Transmission 4 06-08-2013 12:32 PM
