Old 04-03-2015, 07:57 PM   #1
ls1ac
ls1ac's Avatar
Intake resonator removal?
In the just for giggles department, has anyone removed the resonator from the air box?
Would it change the sound from the engine bay?
If you have a SC would the wine be louder?
Would it have an effect on power?
I thought it might give a little more room in the engine bay.
Old 04-03-2015, 09:13 PM   #2
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
Your last point is correct, that's all
Digitalanalog is offline   Reply With Quote
Old 04-04-2015, 02:01 PM   #3
ls1ac
ls1ac's Avatar
I wonder if the original intent was for sound suppression as a resonator, or for flow control as a volume buffer to help with intake pulses. With a SC I would think both are not needed.
I was looking for someone who might have tried it.
Old 04-06-2015, 05:15 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Tried it and put it back in. Cosworth engineers also concluded it was there for reason and it's not to do with sound
I'm on about the main one at the front. The others make no or little difference.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-06-2015, 10:56 AM   #5
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
I mishimoto tested this during their intake development and concluded it was worth a few HP. assuming you meant the resonator and not the sound tube.
http://www.ft86club.com/forums/showthread.php?t=61621
G-Man is offline   Reply With Quote
Old 04-06-2015, 11:07 AM   #6
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Don't do it, you will burn out your flux
Old 04-06-2015, 01:45 PM   #7
ls1ac
ls1ac's Avatar
I have been worried about the flux capacitor from the start.
Thank you for the test data, but somehow it reads differently to me.
On the stock intake with and without the resonator the hp. stays at 167, the torque goes from 133 to 134, and the big difference is in the sound changing from 87 to 90 db.
Torque gain seems very small hp. is the same, so the big difference is in the sound.
They said.
"We also saw a loss in power with the resonator removed, so the resonator should be retained if you are using the factory airbox setup."
That is not apparent in the test data they showed.
So,to me it is used for sound control from their test data.
Thank you for the input, I think I will go for more room.
Old 04-06-2015, 01:54 PM   #8
vtmike
vtmike's Avatar
Drives: Scion FR-S
Removing it caused me to get an AF ratio all over the place when I dynoed.
vtmike is offline   Reply With Quote
Stock resonator removal? jm1681 Engine, Exhaust, Transmission 33 10-11-2019 06:58 PM
Intake resonator?? DIE1000DEATHS Engine, Exhaust, Transmission 16 12-03-2014 08:17 PM
COLD AIR INTAKE INSTALL AND SOUND TUBE / RESONATOR REMOVAL FRSpappa Engine, Exhaust, Transmission 16 06-21-2014 12:13 AM
Intake resonator delete. mid_life_crisis Engine, Exhaust, Transmission 2 09-12-2013 09:14 PM
Vortech intake resonator removal Problem Howardwei Forced Induction 6 08-27-2013 06:47 PM
