Old 05-27-2014, 01:38 PM   #1
Chad_W
Drives: 2013 BRZ DGM
Intake Tube - Is the resonator necessary? Perrin, Mishimoto, et al....
I've been researching the intake tube and its seems like only AVO and Mishimoto have decided to keep the resonator.
Mishimoto shows specific methodical testing proving that the resonator is critical for power.
Perrin's blog shows extensive testing and the resonator is not critical.
Most manufacturers are in Perrin's camp, but the only well documented development is coming from Perrin and Mishimoto and they contradict each other.
I'd love to get Mishimoto's and Perrin's take on this. Along with any other manufacturer who would like to chime in.
Chad_W is offline   Reply With Quote
Old 05-27-2014, 02:30 PM   #2
Davey
Drives: BRZ Limited
Got a link? I really cannot comprehend how the resonator could contribute to power.
Davey is offline   Reply With Quote
Old 05-27-2014, 02:36 PM   #3
phrosty
I'd guess a resonator will affect the flow differently depending on intake design.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 05-27-2014, 02:45 PM   #4
calibrz
Turbo 86
Drives: GT86
most of the case, resonator doesn't do much beside flows the air better on the design of the intake.
10 - 1 = 0
real math
calibrz is offline   Reply With Quote
Old 05-27-2014, 03:14 PM   #5
zooki
Drives: waiting on a 2021...
I don't think it really makes one bit of difference. The aftermarket intake tube a cosmetic item in my opinion.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 05-27-2014, 03:36 PM   #6
Chad_W
The findings from Mishimoto indicated that removing the resonator lost power... this is not uncommon for NA vehicles were removing something OEM in the intake system can cause an issue which reduces power.
Old 05-27-2014, 05:51 PM   #7
Fear
Drives: Ft86
i'll simplify it as best as i understand;
Throttle body opens
Air gets sucked in through intake
Throttle body closes
air moving at speed toward throttle body is stopped
Velocity is then reversed back toward filter as it has no where to go
air then gets compressed into resonator due to low pressure (path of least resistance)
Throttle opens
air is still moving forward from tube toward resonator
think of it as a dampener of the velocity of the intake air.
Dyno numbers gonna change much, probably not
throttle response going to change much.. probably enough to some
my concern would lie in those split moments when the computer is expecting X amount of air and its not there due to the velocity of the air needing to be reversed back into the intake
there is more to intake design then flowing as much air as possible... Sound, throttle response, EPA ... those are just SOME factors
Fear is offline   Reply With Quote
Old 05-27-2014, 07:07 PM   #8
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Looking over Mishimoto's post, they were using the factory intake with their inlet hose. it looks like from their research that they recommended keeping the factory resonator that's connected to the the factory intake, but deleting the sound generator connection in the intake to make the most power when using their inlet hose. We never tested this specifically, since our inlet hose doesn't have the sound generator tube connection.
We decided to remove the sound generator connection completely to clean up the engine bay, and to make the intake tract smoother to make the most power.
PERRIN_Chris is offline   Reply With Quote
Old 05-27-2014, 08:04 PM   #9
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I don't know if you're talking about the resonator on the intake box, or the sound generator. If you're talking about the resonator, I'd assume the loss of power is from pressure wave intake charging. Mazda did it through a really long intake manifold and ridiculously complicated valves in the NA FC's. They called it dynamic intake charging. On a cold winter night at sea level the NA FC Rx-7 can see up to 2 lbs of boost in the manifold. They use the reflective sound waves to keep the intake manifold pressurized when the valve closes(in the Rx7's case once the rotor closes the port). I would guess that removing the resonator changes the pressure wave tuning and thus the loss of power.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 05-28-2014, 09:57 AM   #10
Mishimoto
Drives: 2013 Subaru BRZ
Thanks for checking out our data OP! As mentioned, we conducted extensive testing during the development of our induction hose. A full write-up of our development and testing process can be found at the build-thread below.
http://www.ft86club.com/forums/showthread.php?t=65891
For those not interested in the long read, we found that removing the resonator reduced power. Although not substantial numbers, it is certainly something to consider if you are trying to squeak out every last bit of power. The explanation of the resonators function is explained in this writeup, also noted by Fear above.
Our numbers showed maximum power output (Mishimoto induction hose) with the resonator installed and the noise amplifier removed. After surveying the market we found that most customers were not interested in retaining their noise amplifier, so we removed the port from our hose.
Feel free to follow-up with any questions regarding our testing or induction hose.
Mishimoto is offline   Reply With Quote
Old 05-28-2014, 01:48 PM   #11
Akari
Drives: 2013 DGM BRZ
All of your testing was performed with the OEM tune correct? -I'd be curious to see if the opposite result is found when tuning for the different characteristics of an intake without this resonator. It would make sense to me that the OEM tune, expecting behavior similar to the OEM intake would benefit from a resonator still being in place.
Akari is offline   Reply With Quote
Old 05-28-2014, 03:42 PM   #12
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
This thread is a bit all over the place...OP is comparing stock airbox/snorkle/aftermarket filter/aftermarket inlet hose (apples) with a cold air intake that throws everything stock away (potatoes). They're going to act very different. Perrin and Mishimoto were working toward different goals in their respective designs.
I don't think that you're going to arrive at any valid conclusions from this type of comparison. And then start throwing in the variable of tuning...good luck.
I will say though, I have a Mishimoto hose and aFe panel filter coming in the mail...
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 05-28-2014, 04:08 PM   #13
Akari
That's exactly my point. People are claiming having the resonator is critical for power which has only been verified for a computer tuned to run with a resonator. Most real power gains with intake/exhaust are only really seen when properly tuned for the changes. Often times systems that mimic the OEM design are slightly improved when running the OEM tune but fail to perform at the level that a different design, properly tuned can.
It's very unfair to say a resonator is critical for power until we see more testing.
Old 05-29-2014, 10:46 AM   #14
Mishimoto
This is correct. All of our testing (Both our induction hose and intake) was completed using the factory tune. Unfortunately we did not investigate the effects of additional tuning on the removal of these additional intake components. That would certainly be an interesting test.
mishimoto, perrin
Perrin intake tube kasikuusi Engine, Exhaust, Bolt-Ons 4 04-12-2014 03:19 AM
FS: MISHIMOTO INTAKE TUBE BlackyRose Engine, Exhaust, Bolt-Ons 4 03-09-2014 04:17 PM
SOLD : Mishimoto Silicon Intake Tube and K&N Air Filter 355rockit Engine, Exhaust, Bolt-Ons 13 02-14-2014 11:08 AM
intake tube without resonator increases sound? Sphirit Engine, Exhaust, Transmission 4 02-10-2014 12:29 AM
perrin pulley perrin intake tube Area51 Engine, Exhaust, Bolt-Ons 4 04-05-2013 06:11 PM
