Old 08-11-2012, 02:06 PM   #1
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
Intake resonator??
First, I searched... No, I'm not talking about the "noise generator". I'm curious as to the purpose of this box pointed to in the pic. Is it for harmonics, or some other function? I want to yank it it for underhood cleanliness, but am unsure of its true purpose..Name:  ImageUploadedByTapatalk1344708385.491750.jpg
Thanks!
DIE1000DEATHS is offline   Reply With Quote
Old 08-11-2012, 02:18 PM   #2
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Is that your intake?
Lee358 is offline   Reply With Quote
Old 08-11-2012, 02:50 PM   #3
DIE1000DEATHS
TechNINJA
Yessir
Old 08-11-2012, 03:00 PM   #4
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
Looks so much better without that stupid T-off for the noise generator.
eriktherod is offline   Reply With Quote
Old 08-11-2012, 03:35 PM   #5
thermobox
Drives: 16 Impreza 5dr CWP
Subaru references the whole part as the "Air Cleaner Case Sub Assy". I would assume it is there for noise and water diversion.
Like the old snorkus they had in the Impreza models.
thermobox is offline   Reply With Quote
Old 08-11-2012, 05:01 PM   #6
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
It be nice to have your intake without the straight section (one piece), and in black.
None the less nice.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 08-11-2012, 06:27 PM   #7
wheelhaus
wheelhaus's Avatar
Maybe, but the Impreza snorkus clearly deflected airflow in such a way that any debris or liquid water would drop into it's gullet. This looks like it's plumbing connects to the side of the filter box, not even a low point or anything... Now I'm also curious wtf it is...
wheelhaus is offline   Reply With Quote
Old 08-11-2012, 07:07 PM   #8
wheelhaus
wheelhaus's Avatar
Perrin's intake thread says it's a resonator. They have another pic showing the snorkus, but it's more of a nutsack that hangs from the large intake tube, just underneath where the interior noise generator splits off.
Old 08-11-2012, 07:08 PM   #9
ahausheer
Re-member
Drives: Toyota camry
It is a helmholtz resonator. It is there for sound reasons and possibly to tune the resonance of the intake to aid in airflow. There are actually 3 of them, two are smaller and are behind the front bumper, just about all cars have them. They are not for water. Intakes are often finely tuned like an instrument, changing the shape could result in less airflow although I doubt it would make a significant difference. Google helmholtz resonator for more info.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 08-11-2012, 07:33 PM   #10
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
The resonator helps with the airflow into the engine. As the valves open and close quickly the closing of the valves sends a shockwave of high pressure air back in the opposite direction of airflow. The resonators are made so that the shockwave reaches the end of the intake and bounces back at just the right time to push air in during valve opening.
Xanatos is offline   Reply With Quote
Old 08-11-2012, 08:10 PM   #11
DIE1000DEATHS
TechNINJA
Thanks all, looks like it's staying for now...
Old 10-15-2014, 04:09 PM   #12
bababooey
Drives: BRZ SWP Limited -6MT
haha just coming across this. did the stock tube & noise maker replace recently with perrin tube. when I did I couldnt figure why that thing was there and ripped off that box that connected to the airbox. cracked the plastic a little bit. and used duct tape to seal it up for the time being.
Old 10-15-2014, 06:33 PM   #13
Turdinator
Señor Member
Turdinator's Avatar
You can buy plugs for hole left behind. Looks a lot cleaner that way.
http://www.ft86club.com/forums/showthread.php?t=44579
1974 TA22 Celica
2013 86 GT
Old 10-16-2014, 10:50 AM   #14
bababooey
thanks for the link. i unfortunately broke the rivets but that single plug looks way cleaner than the grey tape currently sealing that end
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
Resonator delete? Sound with stock muffler? Nate219BRZ Engine, Exhaust, Transmission 23 09-05-2012 06:42 PM
GRD intake kit. jet86 AUSTRALIA 9 07-09-2012 09:51 PM
HKS Intake Kit mickey177 Engine, Exhaust, Transmission 1 06-27-2012 07:51 AM
Exhaust baffle/ box structure between cat and resonator? ahausheer Engine, Exhaust, Transmission 14 04-25-2012 01:57 PM
