Drives: 2014 SWP BRZ
Opinions: Tein Flex A or RCE Tarmac/Bilstein
Just looking for opinions here. My wheels & Tires just came in Enkei Rpf1 17x9 +35. Now I need my suspension before I mount them. I had my heart set on RCE Tarmac springs with Bilstein B8's. Now that the Flex A's are out for about the same price it's thrown a wrench in my plan.
Car is my daily with approx 6-12 auto x per year. Only dropping 1in so lowering adjustability is not the issue. Just curious which option would have the better spring rates/valving for the amateur auto x'er & DD. Tarmacs are 5k Teins are 6k. Teins are stiffer but as we all know stiffer does not mean better handling. |
Drives: DGM BRZ
I'm considering the same options. But, I'm leaning towards doing nothing for now and saving for something better. Suspension is one area where it's worth stretching the budget a bit. If you're staying in that price range I would look into Fourtin Auto, or Feal. They have nice entry level options for slightly more than the ones you are considering.
Drives: 2013 FR-S Argento
Guys, one thing that swayed me to the Teins (actually I have the Street Flex, similar to the Flex Z/A) is the camber plates included. If you do any kind of performance driving you'll want have some negative front camber. You can get there somewhat with camber bolts, but really you'll need more than that to get over -1.5 degrees in the front. The Bilstein dampers are probably higher quality than the Tein dampers, but add several hundred dollars to your Bilstein budget for those camber plates. The Tein springs and dampers are matched by Tein - I'm unfamiliar with how well the Tarmac springs are matched to the Bilstein dampers (probably fine). FWIW I just installed my Tein suspension and aside from some increased rear noise I love them.
I don't have first hand experience with the Teins, but I've read that the damping is quite soft. I'd like to go for a ride.
You might want to consider the Bilstein B6 instead of the B8. There is no difference in valving, only the reduced droop travel and probably a shorter internal bumpstop. You can open the Bilsteins to trim the internal bumpstop or run as is. This saves you a little bit of money over the B8s. I do really like the Bilsteins, which have the nice feature of being easily revalvable. Camber plates would indeed be very helpful. We have our RCE Street plates but that may push you out of your budget. - Andrew |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
Drives: FR-S Whiteout
If the flex a damping is anything like the flex z, which I believe it is according to Tein's marketing material, it will be quite soft and compliant. The words "cadilac" and "camry" come to mind (5 clicks out from full stiff). I haven't had a chance to really throw it around yet nor have I tested the firmest settings (customer's car), but I will soon once he bring it back to me to check and re-torque everything.
Intent > Content
cowardice is the mother of cruelty. |
#6 | |
Intent > Content
#7 | |
Sorry, but I have to say something was wrong with his dampers or call BS on that. You sure they weren't defective? Were they set up correctly? Yeah I'm not a track junkie on r-comps so my "requirements" aren't for a track ready suspension, but there's nothing going on like what you're alluding to. No pogo-ing, catching air, etc. Actually the opposite, the suspension complies to the road and does a better job of keeping the rubber on the pavement. To give some context, I was a skeptic of the Teins but I took the leap anyway because they were 'cheap' with camber plates - I thought what the hell, I can always resell them. Lo and behold, I'm quite happily surprised - compared to stock with springs: a very noticeable improvement in grip & responsiveness, corners much flatter, more confidence, more compliant over rough roads, slightly improved steering feel. Anyway I don't want to sound like a Tein advertisement - you'll get all the above with the Bilsteins too, but coming from someone who has the Teins and actually has *no* bias, the Teins work pretty darned well for performance street driving (and I imagine a marked improvement over stock on the track). |
#8 | |
I haven't driven his car so I can only judge from what I see his car doing over the bumps, and that thing pogos.
Intent > Content
#9 | |
| The Following User Says Thank You to bfrank1972 For This Useful Post: | solidONE (11-04-2015) |
#10 |
I've read that 'full stiff' on budget dampers isn't always 'full stiff' worth a shot to try a couple other settings imo.
#11 |
My friends that were playing with the adjustments have engineering backgrounds. I can assure you they've tested the entire range of adjustments. lol (*really anal mofos)
Intent > Content
| The Following User Says Thank You to solidONE For This Useful Post: | strat61caster (11-04-2015) |
#12 |
Thanks everyone. Looks like bilstein's it is. Seems more suited to my application and needs.
@Racecomp Engineering, thanks for the reply. Budget really isn't an issue. I'm just not down for paying big money for stuff I would rarely take advantage of. I was originally considering your T0's or T2's but for my every other month auto x and maybe 1-2 times a year track days the t2's would be overkill. Top hats and rear LCA's are in the plan. This way I can have a nice -1.5/-2 of front camber for DD then easily change it for autocross. How do your street camber plates compare to the RACESENG plates. They look very similar. I plan on getting either of the two. Last edited by ChrisSC300; 11-04-2015 at 05:28 PM. |
| The Following 2 Users Say Thank You to ChrisSC300 For This Useful Post: | Racecomp Engineering (11-04-2015), strat61caster (11-04-2015) |
#13 |
The Fail Boat
Drives: CWP S.B.
^ for myself I decided on Tein A, but know that Bilstein B6 is very good. JDM yellow STI damper is actually a custom set of B6s. :p
#14 |
AutoX-10/10ths every run
You might also consider the RS-R Club Racers: http://counterspacegarage.com/rsr-sp...ubaru-brz.html
They include camber plates with spherical bearings that can allow you to get up to -3 degrees camber in the front. They come with 8K springs square, and you can adjust ride height independent of piston stroke position. I've been daily driving a set on my car for almost a year, and the range of damper adjustment will allow for a smooth ride on rough streets as well as heavier damping for Auto X events.
| Help wanted: Tein Street Flex for $950 or Flex Z or $820? | chezzy79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-01-2015 10:33 PM |
| Bilstein B14 vs Tein Flex vs ISC N1 vs MCA Blue (Coilovers) | xkwizt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 02-24-2015 06:10 PM |
| Switched from RCE Yellows to Bilstein B8/RCE Tarmac Springs | was385 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 01-24-2015 12:19 AM |
| Review: Bilstein B8 + RCE Tarmac lowering springs. | Turkish | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-04-2014 03:30 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 02:10 PM |
