Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
Review: Bilstein B8 + RCE Tarmac lowering springs.
Howdy y'all! I am reviewing the suspension components listed in the title, which I installed earlier this week on Monday. I will not be discussing the install in this post, but feel free to ask and I'll try to answer to the best of my ability (NB: the stubs on the oe top hats are weak and 1 ft-lb of torque over specification will result in sheared studs).
About my car: The pertinent info is that other than the shocks and springs everything related to the suspension is oem, even the wheels and tires. Front rates: 5.0k Rear rates: 5.1k On dry asphalt, the car is well planted for cornering. I now have -1.8/2.0 degrees of rear camber as measured on my alignment performed yesterday morning. On a stretch of twisty road that will be my benchmark for all suspension work, I was able to maintain speeds through the turns that were 5-10 mph higher than I was able to do previously. When the nannies are on, VSC is triggering significantly less than before as well. The car is very balanced right now in terms of oversteer/understeer. On wet asphalt, the car is very twitchy and does not not like it. I believe this to be due to the stock Primacy tires having less wet traction and the stiffer suspension exacerbating that performance weakness. What I have noticed now with the stiffer suspension, is a significant increase in drivetrain movement when shifting between acceleration and deceleration. As with any plan, they change; so instead of my next step being sway bars to fine tune suspension, I will instead probably work on securing the drivetrain in ways that will keep me legal for the STX class of AutoX. The Bilstein shocks do have a bit of a break in period where they feel a lot harsher than what they will settle to. That said, if you want a comfortable ride you probably will want something different. Sent from my SCH-I535 using Tapatalk
| The Following 5 Users Say Thank You to Turkish For This Useful Post: | DAEMANO (06-04-2014), fooddude (05-09-2014), fstlane (05-09-2014), husker741 (06-04-2014), Racecomp Engineering (06-04-2014) |
Serial Cone Killer
Redipping rear wheels, then I'll take pictures to show stock wheels with B8/Tarmac effects on overall stance. I'm not part of the "stance scene" and do not mean to imply any such thing.
Drives: 2014 Whiteout Monogram Frs
how much stiffer is this setup than stock?
Serial Cone Killer
Springs are 280F/290R, oem is 131F/181R if I recall correctly. The only significant difference in the dampers is the max length is shorter, but I don't recall the difference; all else is supposedly the same as stock though.
Sent from my SM-G900V using Tapatalk
Serial Cone Killer
Also in autocross, the lack of negative camber in the front contributed to a lot of understeer in extreme cornering situations. I gave since added -1.2* in the front and have my next autocross event this coming Sunday.
Member of the year - 2016
Drives: Scion FRS
Do you think it's worth it? You don't seem super satisfied with the buy.
Serial Cone Killer
I'm actually very satisfied with the buy, I'm a car mod newbie and didn't realize what else I needed to do. I'm still reserving final judgement until this coming autocross.
Afterthought edit: The car is now at the stiffness I first expected prior to test driving the car. Despite being a half to three quarters of an inch dropped, the car actually bottoms out on road dips less than stock. Sent from my SM-G900V using Tapatalk
| The Following User Says Thank You to Turkish For This Useful Post: | dem00n (06-04-2014) |
Hes on stock tires, so the 'limit' of the car before was hindered signficantly by grip. I feel he didn't get a great base line to compare.
| The Following User Says Thank You to vroom4 For This Useful Post: | Turkish (06-04-2014) |
#9 | |
Serial Cone Killer
#10 |
No, the rap they get is because they stick worse than a mid-range all season and handle heat like a snow tire
![]() What you running the shocks at? |
| The Following User Says Thank You to vroom4 For This Useful Post: | gramicci101 (06-04-2014) |
#11 |
Drives: MT WRB BRZ Limited, 2007 911s
I pulled the trigger on a set. I'll be moving from RCE yellows/stock dampers and 245 ZIIs to this setup for my budget-minded STX build. It'll be interesting going from a non-stock setup to the B8-Tarmac setup and should provide a different perspective (doesn't seem to be much experience with this setup on the forums).
| The Following User Says Thank You to was385 For This Useful Post: | Turkish (06-04-2014) |
#12 |
Thanks for the feedback! Glad you got your alignment sorted, now it's time for some real tires.
![]() We designed the RCE Tarmacs as a small step above our RCE Yellows in performance for those that want a little more edge while keeping a fixed perch damper to keep things simple. Not really intended for stock tires...we expect most would run them with a stickier summer street tire. Also designed specifically for aftermarket dampers like Bilstein or Koni. Our RCE Yellows are softer and more of a OEM Sport+ option that can work well on stock shocks for a DD and some light auto-x or track time. Still a good handling spring and perfectly fine with stock tires or something a little stickier. Better ride quality with those but the Tarmacs will handle better. Yes Bilsteins do seem to soften a bit after install. I think the B8s are a good shock (love the gas pressure) but I wish that they were not shorter in overall length. Makes me consider B6s as the better choice BUT those probably have a longer bumpstop internally, so the B8 is probably the way to go. - Andy |
#13 |
double post? what is this 2004
#14 | |
When I install this setup, do I just leave off the supplied front bumpstops because the Bilstein struts include an internal one? Just run the tarmac bumpstops for the shocks? |
| Suspension Review: Eibach Pro-Kit Lowering Springs | DarrenDriven | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 136 | 10-09-2020 06:26 PM |
| BRZ DRIVEN FULL REVIEW (lowering springs pics too) | Racecomp Engineering | BRZ First-Gen (2012+) — General Topics | 99 | 12-14-2019 05:14 PM |
| Suspension Review: Eibach Sportline Lowering Springs | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 129 | 07-23-2019 09:59 PM |
| RCE Springs from Tarmac Zero - 280# NEW | jack43 | Brakes, Suspension, Chassis | 0 | 03-22-2014 02:41 PM |
| CG 35mm Lowering Springs Review (PICS) | Tylub | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 05-29-2013 04:54 PM |
