Old 11-01-2015, 01:44 AM   #1
dddavidv
Drives: Subaru BRZ Special Edition
Header and Front pipe suggestion?
Hi guys, I'm currently looking to get headers (uel) + a front pipe to go along with my 2.5 Perrin (resonated) catback.
I'm currently looking to get a bit of a louder setup and rumble out of these mods as the perrin catback is a little too "boring" for my liking :P
Any suggestions? (I live in Australia)
Thanks in advance!
dddavidv is offline   Reply With Quote
Old 11-01-2015, 01:52 AM   #2
steve99
Thanks in advance!
you might want to have a read the "Basic Bolt On Mods Guide" link below.
Cat less header alone will make your car much louder (and you will trigger CEL code)
Without a tune your header will not generate much power increase just noise.
Cat-less header, high flow cat/cat-less front pipe and perrin exhaust (even resonated) is going to be pretty loud. The stock cat in front pipe cuts down a fair bit of rasp and noise.
Everyone judgement of loud varies though :-)
Maybe just do the header first and see how loud it is then maybe do frontpipe/overpipe in one go later on.
Old 11-01-2015, 01:15 AM   #3
dddavidv
Ahh right, thanks for that! Oh and any suggestion on what uel header to get?
Old 11-01-2015, 02:07 AM   #4
steve99
UEL in Australia go the PSR basicly same as Tomei UEL header or Gruppe-s UEL, but the PSR comes with overpipe and gaskets that worth at least $200. aussie seller so no exchange rate issues.
http://www.prospeedracing.com.au/pro...scion-frs.html
Where are you is australia as your going to need a tune for those headers
The Open flash header/Openflash tablet was good value a couple of years back but bad exchange rate to USA dollar and shipping make it a bit dear now, but still reasnoble value depending on what your local tuner charges.
Tune and header comes in arround $1500, might be an option depending on your tune options in your area.
http://www.openflashtablet.com/Autom...OFH/index.html
Old 11-01-2015, 03:43 AM   #5
dddavidv
I'm in melbourne, I've been doing a bit of research and right now I can say i'm looking towards getting the PSR uel.
Old 11-02-2015, 05:03 AM   #6
tzbang
Drives: 2013 GT86
Do you think the OFT tunes (made for their OFH design) will work just was well for other headers like PSR or Gruppe-S?
I'm trying to decide on a header but I'm in NZ, PSR would probably be the closest one to ship. But not sure how well the OFT tunes will go on that along with our 95RON fuel (equivalent to US 91Octane I think)
tzbang is offline   Reply With Quote
Old 11-02-2015, 05:11 AM   #7
steve99
The oft uel header tunes work fine with psr uel header
with 95 ron fuel you may need to dial the ignition timing back a bit and adjust the di\pi tables to run full di to 7000 not 5000.
see thread here
http://www.ft86club.com/forums/showt...47#post2216047
see @Wayno,s tune thread links in his signiture, hint wayne has psr uel header :-)
and links below
Old 11-02-2015, 03:33 PM   #8
tzbang
Drives: 2013 GT86
What sort of fuel do you aussies have? We've got 98Ron at sporadic BP stations. That's about as good as it gets, and it's expensive. E85 is race fuel you have to order in or available at some Gull stations only in the North Island.
I'm in the south island.. and I've got a company fuel card but only for 95RON unfortunately.
Hows the collector look in the PSR header? Is it as nice as the Gruppe-S ?
Old 11-02-2015, 04:21 PM   #9
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
steve99 is too nice to OP.
this has been covered many times.
my suggestion is SEARCH!
Old 11-02-2015, 08:01 PM   #10
brzbrad
[||•]=(86)=[•||]
brzbrad's Avatar
Drives: 2014 BRZ Limited WRB
I have the Tomei UEL catless headers, Tomei overpipe, Invidia catless front pipe, and the same Perrin cat back as you. It sounds great but is very loud... Especially the cold starts. I don't think it's to loud though, and it doesn't drone too bad on the highway. With a tune, it got rid of the torque dip in low RPM's as well
[ame="https://www.youtube.com/watch?v=QNF7TwieaeU"]https://www.youtube.com/watch?v=QNF7TwieaeU[/ame]
<a href=http://www.ft86club.com/forums/showthread.php?t=91507 target=_blank>Build Thread</a>
brzbrad is offline   Reply With Quote
The Following 2 Users Say Thank You to brzbrad For This Useful Post:
10Stars (11-02-2015), YangerD (11-03-2015)
Old 11-03-2015, 12:42 AM   #11
steve99
The collector on PSR header is simialr to gruppe-s and tomei. ie pterry good better than a lot of cheaper headers.
We have 98 ron but its appears slightly inferior to european 98 ron and certianly not as good as usa 93 AKI fuel, probably about USA 91.
We also have pump E85 one thats guaranteed E85 and another thats e-flex varies between 60-80% its about $1 a litre the good stuff is about $1.30 AUD
You can get these car to run on 95 ron safely but you do have to back the timing off in some areas and also run more DI fueling percentage than the stock tune runs.
They will run on 95 on the stock tune but not well and have considerable knock constantly.
see below you need to move to Australia mate :-) we can get this at pump
Old 11-03-2015, 12:43 AM   #12
steve99
you can "tune out" the loud cold starts. see tune tweaks link below
brzbrad (11-03-2015)
Old 11-03-2015, 12:51 AM   #13
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
http://www.prospeedracing.com.au/pro...t-coating.html
OR
http://aceheader.com/index.php/gt86-...and-rhd-detail
+ ceramic coating.
Wouldn't touch anything else right now.
Old 11-03-2015, 01:54 AM   #14
brzbrad
[||•]=(86)=[•||]
brzbrad's Avatar
Interesting... I personally like the cold start, but my neighbors, probably not so much. No complaints yet so until then, she's staying loud
The Following User Says Thank You to brzbrad For This Useful Post:
Strife26 (11-07-2015)
Best Catback/Front Pipe/Over Pipe/Header Combo for the BRZ? O.Z. BRZ Engine, Exhaust, Transmission 22 04-17-2019 09:44 AM
Ceramic coating header only vs header/over pipe/front pipe pixel67 Forced Induction 8 08-18-2015 02:39 PM
MXP UEL header/over pipe combo and front pipe Gixxersixxerman Engine, Exhaust, Transmission 6 09-06-2014 04:13 PM
About to order HKS header & front pipe. To go cat or no cat? BenArmstrong Engine, Exhaust, Transmission 21 06-25-2014 12:38 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
