Drives: 2013 Subaru BRZ
OFT Stage 2 stock headers
Would it be safe to use stage 2 EL 91 octane tune with stock headers?
#FiftyShadesOfBlue
Drives: 2015 FR-S
Not to be a **** but....I'm pretty sure it clearly says to only run stage 2 with aftermarket/catless headers. Why does everyone ask if something will be ok when it is advised against? /rant
If you are on e85 you can run the e85 stage 2 tune on a stock car. Edit: Running E85 on a stock car http://www.ft86club.com/forums/showthread.php?t=67310 Definitely worth reading everything through multiple times before swapping over. Not a difficult process just make sure you understand what you are doing. There is also a stickied thread where you can post your data logs afterwards and will usually get helpful advice
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() Last edited by Tectoniic; 10-06-2015 at 06:38 PM. |
I read it, but I was digging around and saw a few that ran stage 2 on stock. Sorry I'm a noob and still slowly learning. I can just fill up on e85 then. Would it be UEL e85? Or EL 85?
Drives: Toyota 86 GTS
You didn't say anything about e85 in your post
@Tectoniic answered my first question. I'm asking now if I can fill up on e85 on a stock frs/brz and use stage 2 with the EL e85 tune or UEL e85 tune.
Slow Learner
Drives: 15 Halo FRS
Your stock header is EL. There is an entire thread dedicated to E85.
I have found people to be very helpful here _provided you have done some basic research_ but they arent going to spoon feed you. The E85 thread will be easy to find. |
Drives: brz
sounds like you want to do stage 2 cause it sounds cooler than stage 1 but the only difference is the tune it adjusting for the catless headers
| Our Stage 2 E85 OTS map tested on stock car | Shiv@Openflash | Software Tuning | 103 | 05-03-2019 07:41 PM |
| Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 | FRSTEVE | Software Tuning | 105 | 08-04-2017 04:48 AM |
| Near Stock v. OFT Stage 2 Dyno | DarkSunrise | Engine, Exhaust, Transmission | 74 | 11-15-2014 09:48 PM |
| TOMEI UEL vs. EL headers (w/stage 2 OTS tune) | UrmyboyBLUE | Engine, Exhaust, Transmission | 42 | 10-25-2014 02:16 AM |
| Anyone have an Exedy Stage 1/2 in stock? | draggin_az | Engine, Exhaust, Transmission | 0 | 07-18-2014 08:13 AM |
