Old 10-05-2015, 03:30 PM   #1
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
4.556 final drive with TRD gear ratio change - good or bad idea?
I'm thinking of doing the Toyota OEM final drive of 4.556:1 (same as Cusco but cheaper here).
I was wondering what it would be like with this AND the TRD cross gear set here http://www.trdparts.jp/release/2015_...ssmission.html
I know the effect the final drive will have and am keen but figured if they were playing around with the transmission I could get them to do the cross gear set at the same time but will the combo be better or stuff up the ratios?
And, yes, I did search but couldn't find out info about the combined effect.
nzer is offline   Reply With Quote
Old 10-05-2015, 03:56 PM   #2
swarb
final drive changes the ratio about 10% shorter.
higher final drive makes 3,4,5 gears more usable on a track.
trd gear set would make 1,2 usable on the track and closer gearing between 2nd and 3rd.
The Following User Says Thank You to swarb For This Useful Post:
nzer (10-05-2015)
Old 10-05-2015, 04:00 PM   #3
mrk1
Drives: Sterling BRZ Ltd
4.56 is a very nice upgrade for a NA car.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
kodyo (10-06-2015), nzer (10-05-2015)
Old 10-05-2015, 04:23 PM   #4
Sargy
Long Distance Driver
Sargy's Avatar
I Plan on it @nzer. I already have a 4.8!
I already envisioned the shorter change from 2nd to 3rd. Excited
Sargy is offline   Reply With Quote
The Following User Says Thank You to Sargy For This Useful Post:
nzer (10-05-2015)
Old 10-05-2015, 08:19 PM   #5
nzer
nzer's Avatar
Thanks for the feedback all. I've decided to do final drive first and consider gearing later. cost of gearing option is pretty steep with parts then quite a lot of labour as can't do it myself.
Old 10-05-2015, 09:01 PM   #6
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
The 4.56 Final drive swap is a great upgrade to the car, It helps overall feeling throughout the car, but still maintains very derivable mpgs
[ame="https://www.youtube.com/watch?v=occuNSTlkIo"]UEL E85, 4.56 FD swap 0-80MPH - YouTube[/ame]
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following 2 Users Say Thank You to Aztec For This Useful Post:
chaoskaze (10-19-2015), nzer (10-06-2015)
Old 10-05-2015, 10:06 PM   #7
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Do it! TRD stuff is obviously very good..... + this is actually one of the upgrade option for 86 in Japan when you purchase the car from dealer.
The Following User Says Thank You to chaoskaze For This Useful Post:
nzer (10-06-2015)
Old 10-06-2015, 03:05 AM   #8
GT86_PRAGUE
Drives: GT86
You might be interested in my thread:
http://www.ft86club.com/forums/showthread.php?t=94450
Today my car is in a shop switching 4.67 to 4.88. Then I will decide if I buy Cusco cross mission set or nothing.
Edit: I dont think you need longer gears on 4.56 FD, I run autocross here in Europe with 4.67 and it is manageable, but for 4.88 it will be probably too short. I will know for sure next week.
GT86_PRAGUE is offline   Reply With Quote
The Following User Says Thank You to GT86_PRAGUE For This Useful Post:
nzer (10-06-2015)
Old 10-06-2015, 08:24 AM   #9
rx3
With the 5.125 ratio the second might become a long first and fifth could finally be used in a fast slalom. (But I think according to EU-law any change exceeding 8% needs to go through an individual approval procedure by a dedicated inspection agency = extremely expensive).
rx3 is offline   Reply With Quote
Old 10-06-2015, 08:25 AM   #10
GT86_PRAGUE
Drives: GT86
And who will ever know you have a shorter gear somewhere inside?
Old 10-06-2015, 11:43 AM   #11
rx3
That's a good point.
We have to get the car inspected every 2 years and usually they take it on a very short test drive and this is where they could notice it. But this really depends on the person who's driving it.
Old 10-06-2015, 12:25 PM   #12
stevesnj
stevesnj's Avatar
Use this tire/wheel size calculator before you select a rear gear ratio
http://tire-size-conversion.com/gear-ratio-calculator/
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Metabrz (10-28-2015)
Old 10-06-2015, 06:37 PM   #13
Sargy
Sargy's Avatar
it will be unless its a very VERY small course. majority of all of my autocross courses require 3rd gear with only 1 course that I can bang off the limiter in 2nd.
Old 10-07-2015, 05:31 AM   #14
GT86_PRAGUE
Drives: GT86
You know - Europe is different, we have everything smaller
Well, not everything.
How-To: Change final drive ratio (relatively) cheaply PantsDants Engine, Exhaust, Transmission 84 03-22-2020 03:58 PM
Change gear ratio? Afdad120108 Engine, Exhaust, Transmission 61 08-17-2016 10:44 AM
taller final drive ratio SuperDave Engine, Exhaust, Transmission 17 10-26-2014 03:37 PM
About track cars' final drive ratio immo Tracking / Autocross / HPDE / Drifting 4 09-23-2014 09:04 AM
Gear Ratio Change Lunatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 06-26-2014 10:20 PM
