Old 10-03-2015, 06:12 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Question Rear Differential Bushing Bolt Torque Specs?
I'm installing the Avoturbo rear differential bushing inserts and I'm having trouble finding the torque specs for the 3 bolts.
To be clear these are not the subframe inserts but the actual pumpkin rear bushings that are circular.
any help would be appreciated. I have a partial shop manual but can't seem to find them in the PDF file.
Thanks as always.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 10-03-2015, 06:39 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
the 3 bolts connected to the very back of the diff (2 bolts on drivers side, 1 on passenger side) are 46ft.lbs
the two connected to the frame?(Installed vertically, on front of diff) are 70ft.lbs
The Following 11 Users Say Thank You to continuecrushing For This Useful Post:
200hp/tonne (03-27-2016), BlaqkHavok (07-01-2019), chanklins (01-11-2020), Escher (12-05-2021), Insurme1 (04-03-2017), Kestrel (11-02-2016), NRXRaptor (12-23-2017), rns294 (12-29-2020), Somerandom18 (07-17-2017), Strife26 (11-06-2017), villainous_frx (05-23-2021)
Old 11-06-2017, 10:36 PM   #3
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Old, but you rock!
Sent from my SM-G950U using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
The Following User Says Thank You to Strife26 For This Useful Post:
continuecrushing (11-07-2017)
Rear suspension torque specs and diagrams from service manual. oc-drummer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-01-2015 12:22 PM
ACT bolt torque specs? drambo136 Engine, Exhaust, Transmission 4 07-12-2015 10:42 PM
torque specs for front and rear subframe bolts mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-17-2015 02:54 PM
OEM Rear LCA Bolt Specs Philly758 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-29-2014 08:34 AM
Torque specs for rear toe arm Malt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-02-2014 07:24 PM
