Old 06-16-2015, 02:58 PM   #1
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
torque specs for front and rear subframe bolts
cant seem to find it anywhere.. anybody? I`m installing the rigid collars on the car and the instructions are in japanese which does me no good lol.
mokinbird87 is offline   Reply With Quote
Old 06-16-2015, 03:02 PM   #2
gramicci101
Off Topic
Referring to the rear crossmember inserts?
http://www.ft86club.com/forums/showthread.php?t=20920
Old 06-16-2015, 03:09 PM   #3
mokinbird87
BOXER FR
hmm... didnt see any torque specs on there...
Old 06-16-2015, 03:14 PM   #4
gramicci101
Off Topic
@F1point4 puts the torque specs on the pictures themselves. It looks like 107 ft/lbs for the four main bolts. They're also on the second picture showing the manual's breakout image. Where it says "145 (1479, 107)," the 107 is ft/lbs. I think the 145 is nm and the 1479 is kg/mm, but don't quote me on that.
Old 06-16-2015, 03:16 PM   #5
mokinbird87
BOXER FR
how did i miss that..!
Old 06-16-2015, 03:17 PM   #6
mokinbird87
BOXER FR
now i just need the front ones...
Old 06-16-2015, 03:21 PM   #7
gramicci101
Off Topic
Also 107 ft/lbs for the large bolt and 52 ft/lbs for the two small bolts.
Old 06-16-2015, 04:36 PM   #8
mokinbird87
BOXER FR
i mean the front cross member though... not the front of the rear subframe thanks for all the help.
Old 06-16-2015, 08:56 PM   #9
gramicci101
Off Topic
I don't know. What are you installing on the front crossmember? A brace?
Old 06-16-2015, 09:55 PM   #10
zeal86
zeal86's Avatar
Drives:
Maybe you can find your torque values here.
See first post...
projekt zeal86 build
zeal86 is offline   Reply With Quote
Old 06-17-2015, 12:40 PM   #11
mokinbird87
BOXER FR
I`m installing the rigid collars. now I`m really confused.. why do i have to remove the steering linkage? anybody speak japanese? LOL
Old 06-17-2015, 12:43 PM   #12
mokinbird87
BOXER FR
but i guess i found the torque specs.. just need to understand this damn thing lol
Old 06-17-2015, 01:09 PM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@ichitaka05
Old 06-17-2015, 01:27 PM   #14
fika84
fika84's Avatar
Just get under there and see how it goes. I would assume it's just for more clearance for something, but you won't know until you try. It's not that many bolts to give it an attempt.
fika84 is offline   Reply With Quote
Eibach Sportline Lowering Spring front and rear camber bolts WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-20-2014 10:09 AM
Torque specs for rear toe arm Malt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-02-2014 07:24 PM
REVIEW | DC Sports rear subframe brace / rear subframe lateral brace mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-10-2014 08:59 PM
Eibach sportline, SPC rear LCAs, Whiteline front camber bolts Shad0ez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-17-2013 11:52 PM
Does anyone know the front and rear track specs? spiller Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-21-2012 08:25 AM
