Old 10-09-2014, 12:35 PM   #1
Philly758
Drives: GMC
OEM Rear LCA Bolt Specs
Does anyone know the specifications for the OEM rear LCA bolts, there should be four (hub, shock, sway, frame)? Or where I can get replacement bolts?
I jumped on a deal a little while back, where I traded my OEM LCA's and cash for some Whiteline LCA's. The bolts are not interchangeable between the two, so my stock bolts went with my stock LCA's. Based on my modifications and plans for my car/life, the Whiteline's are overkill, so I was considering selling the Whitelines and just running SPC's with the OEM look and some adjustability.
This is confusing, thank you for your help.
Philly758 is offline   Reply With Quote
Old 10-09-2014, 01:35 PM   #2
pleong
Drives: 2013 Whiteout FR-S
SU003-02782
SU003-02804
SU003-02781
http://www.villagescionparts.com/sho...category=19383
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 10-09-2014, 02:53 PM   #3
Philly758
Drives: GMC
Originally Posted by pleong View Post
SU003-02782
SU003-02804
SU003-02781
Thanks!
Also found the replacement bolt for the shock. SU003-02803.
Old 10-29-2014, 08:34 AM   #4
Supercharged
Appreciate this thread. I'm doing the same thing as @Philly758. Selling my Whitelines because I'm not using them for what they are made for and I'm sure someone else could benefit more.
I had the SPC's at one point and loved them and now I have them again. The only bolt not needed above is SU003-2781 since it has a camber bolt included with the arms. Every other bolt is needed though.
Supercharged is offline   Reply With Quote
Torque specs for rear toe arm Malt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-02-2014 07:24 PM
Bolt-on Rear Wing Rosticles Tracking / Autocross / HPDE / Drifting 33 01-01-2014 11:02 PM
Camber bolt for the rear ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-25-2013 01:49 PM
Rear Sway Bar Stabilizer Bracket Bolt replacement? Books Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-19-2012 03:55 PM
Does anyone know the front and rear track specs? spiller Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-21-2012 08:25 AM
