Old 07-12-2015, 07:58 PM   #1
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
ACT bolt torque specs?
Hey everyone, I got a act hd clutch with a prolite flywheel. Can anyone confirm the torque specs for all the bolts?
Thank you
David
Sent from my SAMSUNG-SM-N900A using Tapatalk
drambo136 is offline   Reply With Quote
Old 07-12-2015, 08:30 PM   #2
DieselDog
Shift it or lose it
DieselDog's Avatar
Drives: 2014 FRS, 2003 Celica GT
If the manufacturer doesn't have them just use standard bolt torque spec for the grade and size of bolt you are using with blue loc tite
DieselDog is offline   Reply With Quote
Old 07-12-2015, 09:04 PM   #3
AlexBinJackson
Drives: 2015 Brz Blue Series Pearl White
Just installed mine last week the flywheel bolts were 63 lbs and the pressure plate to flywheel are 26 ft lbs according to act as its a m8x1.25
AlexBinJackson is offline   Reply With Quote
Old 07-12-2015, 09:08 PM   #4
drambo136
drambo136's Avatar
Did u use the stock or supplied bolts
Old 07-12-2015, 10:42 PM   #5
AlexBinJackson
For flywheel I bought new ones but used supplied bolts on pressure plate to flywheel
Flywheel torque specs D K Engine, Exhaust, Transmission 7 02-07-2021 03:10 PM
torque specs wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-07-2015 11:57 AM
OEM Rear LCA Bolt Specs Philly758 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-29-2014 08:34 AM
Torque specs for rear toe arm Malt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-02-2014 07:24 PM
Torque specs (brakes) CB762 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 09-08-2012 12:26 PM
