Old 07-12-2015, 07:02 PM   #1
Ethan Wagner
Drives: Ultramarine frs
Need help finding a final drive kit
I have the automatic frs. I'm trying to find a good final drive kit for my car. So far the mods I have on it are oft stage 2 uel tune, tomei headers and OP, invidia catless FP, and invidia n1. If anyone has any suggestions that they want to share or recommend that would be great! I'm also looking for a shorter final drive like 4.8 or higher. Thx
Ethan Wagner is offline   Reply With Quote
Old 07-12-2015, 08:08 PM   #2
kodyo
Drives: Scion FR-S
Weir performance has them for a good price. 4.88 is going to get you more in line with what a 4.56 would feel like in an MT. Buy the ring/pinion/solid spacer from weir. Email or call him, he'll know what to send you. If you're reusing the stock diff, you can reuse bearings as well, they'll be in good condition.
Buy new axle and pinion seals from an online Toyota parts place or you can get them from weir, but I'd replace those while you're at it.
FYI, solid spacer replaces the crush washer used to get the preload on the pinion gear bearings correct. It can get loose over time and cause excess wear, so solid spacer fixes that.
kodyo is offline   Reply With Quote
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
Where to buy LSD & Final Drive/Gear? GT86_PRAGUE Transmission and Driveline 0 01-09-2015 08:09 AM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 02:51 PM
Finding Every Opportunity to Drive this Car Chad86 Scion FR-S / Toyota 86 GT86 General Forum 23 07-29-2014 08:26 PM
