Old 09-24-2015, 06:09 AM   #1
kilohercas
Drives: Subaru BRZ (soon?)
FRS VS BRZ Damper (strut)
Hello, i have a question that i was unable to find any answer.
Does damping for FRS and BRZ are the same, or somewhat different ?
Right now i am restoring Subaru BRZ in Lithuania, and my strut was a little bit damaged from accident, and i can't find direct replacement, or buy it from EU dealers ( it looks like part code is different for EDM cars)
I can get Scion FRS strut, but part code is not the same, it ends with 20310CA000 and mine ends with 20310CA120. So parts numbers are different somewhat.
I will use my original spring, i know that it really does have different spring rate.
kilohercas is offline   Reply With Quote
Old 09-24-2015, 09:02 AM   #2
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Both dampers should be the same. -A120 is the Subaru Part#. -A000 is the Scion Part#. There may be an additional part# for the 2015+ version which has a very similar damper made by Sachs (versus SHOWA for early models).
Keep in mind that the right side of the vehicle. Also, they list it as an "assembly" (for Scion) and "complete" (for Subaru)... so it may come with other goodies, but nothing major.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 09-24-2015, 03:11 PM   #3
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
This is good info, I have a set of FRS struts and BRZ struts, one will be getting a lift spacer, the other will be getting swift springs, and I wanted to be sure that I chose the right strut for the right spring, should there be any differences.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
brz, frs, strut
Strut Bar Review: AEM Strut Bar Thoughts and Experiences wu_dot_com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 03-08-2019 04:33 PM
FRS VS BRZ Damper (strut) kilohercas FR-S / BRZ vs.... 1 09-24-2015 03:19 AM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
Damper rates mikepaul21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-03-2014 08:23 PM
Damper crosstalk ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-01-2013 02:21 AM
