Old 09-23-2015, 08:46 PM   #1
ChrisD
ChrisD's Avatar
Drives: GT86
Buzzing sound from engine when ignition half on
I should probably start by pointing out that I crashed the car a couple of weeks ago - but it was nothing too major. Front end body work damage, crash bar, passenger side wing and chassis leg, washer bottle, etc etc, but nothing further back in to the engine bay than that.
Anyway, while I'm repairing everything I noticed that when I turn the ignition half on (i.e. press the Start button twice but without the clutch pressed in, so the engine doesn't start but the electronics all come on) there is a weird buzzing sound coming from the engine. Its not very often that I start the car like that without actually starting the engine at the same time, so who knows maybe it has always done this... but it seems unlikely that I would never have noticed it before.
It isn't the fuel pump or anything else that you normally just hear starting up for a few seconds, you still hear those and they stop after a while as normal... but this other sound doesn't stop. It is like an electrical buzzing sound.
I took a video to try show what it sounds like:
[ame="https://www.youtube.com/watch?v=8pcZCCaCnLE"]GT86 Engine Noise - YouTube[/ame]
You can't tell very well from the video but it isn't a single constant sound, it kind of shifts pitch ever so slightly all the time and almost crackles. I did notice there are two battery terminal like connections on the first part of the gearbox bell housing that you can see, pretty close to where the noise is coming from. But they look to be in normal condition and nothing is loose.
Any ideas?
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
Old 09-23-2015, 08:54 PM   #2
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
Is it possible that it is your ac/heater fan?
RustySocket is offline   Reply With Quote
Old 09-23-2015, 09:12 PM   #3
ChrisD
ChrisD's Avatar
Drives: GT86
It doesn't sound like a fan at all when you hear it in person, much more like an electrical buzzing. I guess it could be something to do with the AC, as the AC condenser is currently not there (old one got damaged and waiting for replacement to arrive, so I figured as long as I don't turn the AC on it will be fine to run it like this for now). I can't see how the condenser being missing would end up with that kind of noise coming from all the way back there though.
Old 09-23-2015, 09:20 PM   #4
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
My car always have buzzing sound from alternator or some electric stuff when it's half on.
Yes it's very loud. I can hear it inside the car too if my music isn't on.
Note: now I think about it, the noise is there whenever my headlight is on.
The Following User Says Thank You to chaoskaze For This Useful Post:
V_86 (09-24-2015)
Old 09-23-2015, 09:34 PM   #5
humfrz
Since you suspect it may be related to the A/C ...... you may consider pulling the A/C fuse to see if the buzzing stops.
humfrz
Old 09-23-2015, 09:37 PM   #6
The relay could be trying to activate it and since it isn't there it just sits and buzzes.
Old 09-23-2015, 10:01 PM   #7
ChrisD
ChrisD's Avatar
Drives: GT86
humfrz
I actually meant to pull that fuse earlier anyway just in case I accidentally put the AC on some time while there's no gas in it. So yeah I'll definitely give that a go tomorrow and see if it makes any difference
Old 09-23-2015, 10:02 PM   #8
ChrisD
ChrisD's Avatar
Drives: GT86
I think that's different to my issue then if its only when the headlights are on. Your noise is probably just the ballast of the HIDs. I get that as well when I put the headlights on, but this other noise happens even when I didn't have the headlights connected to the car at all.
Old 09-23-2015, 11:01 PM   #9
RustySocket
Slow Learner
Drives: 15 Halo FRS
I was just tossing it out there as an idea. I've seen a piece of paper or a leaf get into the fan box on other cars and drive people nuts trying to figure it out.
Pulling fuses isn't a bad idea to eliminate things.
A piece of tubing can be used like a stethoscope to start listening around the engine compartment and may help you locate exactly what is making the sound.
Old 09-23-2015, 11:20 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's the throttle body servo. No biggie. I've heard others that loud.
IIRC it's a micro-stepper motor so depending on its commanded position in relation to the natural cogging, you'll hear lots of noise while it maintains those in-between positions.
I'm not describing it very well but it's ok.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
ChrisD (09-24-2015), johan (09-29-2015), MokSpeed (10-06-2015), strat61caster (09-29-2015)
Old 09-24-2015, 08:18 AM   #11
ChrisD
ChrisD's Avatar
Drives: GT86
Ahh ok, that makes sense. When we first heard it that was our first thought too - that it was the throttle body. But then we thought there's no reason for that to be trying to move when the engine isn't even running... I could understand it moving briefly as like a quick test or prep for the engine starting, but this noise doesn't stop even after 5 minutes of the ignition being half on.
The throttle still seems to work as normal when the engine is running, so I guess I should just assume its ok... but it really doesn't sound healthy when its not running and there's this constant buzzing lol
Old 09-24-2015, 01:11 PM   #12
Ultramaroon
not playing cards
We have some pretty awesome subject matter experts in our 86 gang here in Portland. @johan was generous enough to perform an experiment for us last month. Here you can see a Honda K20 throttle body being controlled by the FA20 ECU.
ChrisD (09-24-2015)
Old 09-24-2015, 02:39 PM   #13
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
I have the same sound that I just noticed recently, I don't think its anything to worry about. More than likely you are used to starting the car before the sound starts, or have the radio on, so never noticed it before.
V_86 is offline   Reply With Quote
The Following User Says Thank You to V_86 For This Useful Post:
ChrisD (09-24-2015)
Old 09-24-2015, 07:41 PM   #14
ChrisD
ChrisD's Avatar
Drives: GT86
Ah thanks for the video - its good to hear the exact same sound in that I guess I'll just stop worrying about it then.
Thanks!
Light buzzing sound from driver-side dash BRZprime Issues | Warranty | Recalls / TSB 51 08-21-2015 10:34 PM
Buzzing/Humming sound at high idle DGM.BRZ Issues | Warranty | Recalls / TSB 5 04-08-2015 09:04 PM
Buzzing sound under glove compartment? l0aded Issues | Warranty | Recalls / TSB 13 03-25-2014 07:20 PM
Buzzing / Compressor Sound from Gas Tank Area Spd229 Issues | Warranty | Recalls / TSB 14 12-06-2013 11:17 PM
Buzzing sound(like hairclipper), gas tank region, car park for 4 hrs solma Issues | Warranty | Recalls / TSB 6 03-20-2013 03:04 PM
