Old 03-11-2014, 04:10 AM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Buzzing sound under glove compartment?
I dont know if it has always been there but I noticed a constant very slight buzzing sound, almost like a cdrom spinning sound coming from under the glove compartment infront of passenger side. The sound is only there when the engine is ON so I assume it has nothing to do with the headunit or music. Is this normal or just me?
l0aded is offline   Reply With Quote
Old 03-11-2014, 10:03 AM   #2
fatherfork
Fears Hiccups
fatherfork's Avatar
Drives: Toyota badged 2013 Whiteout FR-S
I had a rattle around that area which turned out to be the glove box itself. I put a few layers of felt just above the hinges so there would be pressure on them when closed. That took care of it for me, but you may have something different. Worth a shot.
fatherfork is offline   Reply With Quote
Old 03-11-2014, 11:34 AM   #3
OrbitalEllipses
Drives: Attitude
If you start hearing ticking...jump out the car and call the bomb squad.
Old 03-11-2014, 11:43 AM   #4
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Maybe its the sound tube telling you to plug it up?
Old 03-11-2014, 11:51 AM   #5
AdamBomb518
Stealth ***e
AdamBomb518's Avatar
Is your AC/heater on at all? That makes a big difference. I'm gutting my entire interior in the next few weeks and sound deadening the whole damn thing so it should be quiet as a mouse when I'm done. =P
AdamBomb518 is offline   Reply With Quote
Old 03-12-2014, 02:52 PM   #6
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
this is the blower noise.
start car and turn ur blower to 0. then turn to 1. listen. turn to 2. listen.
I had this part replaced twice. It's still making the noise.
Mine is pretty high pitched and drives me nuts...
nos145 is offline   Reply With Quote
Old 03-12-2014, 07:20 PM   #7
l0aded
Addicted
l0aded's Avatar
I have Injen so it's already plugged.
I'll need to test this.
Edit: Well I'll be damned. The buzzing is from the blower. It's there even when the engine is off just didn't notice. When they replaced it did it fix the sound or is this like the HPFP crickets where it comes back immediately -__-;
Old 03-12-2014, 07:35 PM   #8
JS + BRZ
Drives: 2010 MS3
Are you sure your cat isn't hiding in the backseat?
JS + BRZ is offline   Reply With Quote
Old 03-12-2014, 08:16 PM   #9
oaroyale
Drives: Black BRZ
I had a similar issue, check your in cabin filter. I had a very small piece of leaf stuck in there.
oaroyale is offline   Reply With Quote
Old 03-12-2014, 09:35 PM   #10
nos145
Cognite
nos145's Avatar
one of them came back a month after. the second was crap from start.
honestly, I got first gen. It makes so many noises.
body flex from back, this blower noise, HPFP, engine knock at specific rpm during load.
I just turn music on all the time now..
Also, just dropped $2.5k (with tax) on 160k km warranty. cuz i am not willing to deal w this shit long term.
the car drives like a champ thou. so thats what matters most.
Old 03-12-2014, 09:40 PM   #11
l0aded
Addicted
l0aded's Avatar
Got my car Dec 2012 so first gen too. I've been fighting rattles and such for awihle as well haha. Even a leaf got stuck in my tail light before =p
Old 03-12-2014, 09:46 PM   #12
nos145
Cognite
nos145's Avatar
I am considering taking whole car apart and applying some kind of sound deafening material.
latest sound rattle: the plate that is around the sound player rattles in bottom right corner.
also, some wires behind the glove box are making noises only when the glove box is closed.
what are you experiencing? lol
Old 03-13-2014, 01:52 AM   #13
l0aded
Addicted
l0aded's Avatar
I don't know if it is because I installed a backup camera and didn't tie wires correctly but there's a sound behind the head unit slightly to the left. I also had a sound on the roofliner which I pulled apart and put sound deadening inside to fix (3M thinsulate accoustic). This is after I tore apart the car and put sound deadener over the entire trunk and rear quarter panels lol.
Old 03-25-2014, 06:20 PM   #14
l0aded
Addicted
l0aded's Avatar
So I went to the dealer and checked out the buzzing sound. Turns out EVERY FRS and BRZ has this sound so it's not really a problem just the way the car is. So no fix.
Oil? Strange discovery under glove compartment Seungify Issues | Warranty | Recalls / TSB 11 10-21-2013 06:58 PM
Don't let your glove compartment eat your wallet Pneub Southern California 26 08-11-2013 10:48 PM
Making the glove compartment bigger ML Cosmetic Modification (Interior/Exterior/Lighting) 0 12-23-2012 05:29 PM
Glove Compartment Not Closing on the Right Corner mirvine Issues | Warranty | Recalls / TSB 6 08-16-2012 12:46 AM
Glove compartment power outlet Trojan_SC Electronics | Audio | NAV | Infotainment 7 08-02-2012 09:47 PM
