Old 09-18-2015, 07:59 PM   #1
lupindub
Drives: Scion FR-S
How many of you guys actually get the rear deck rattle/clicking solved?
Just curious how many of you guys actually got the rear deck rattle/clicking solved by taking it to the dealer? I don't feel like wasting my time if the dealer can't fix it properly like some people mentioned in other threads.
lupindub is offline   Reply With Quote
Old 09-18-2015, 08:23 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Lots of people fixed it themselves. The original fix was to punch the spot welds. But some had success by just spraying lithium grease in the gaps. Both solutions were in the clicking thread in the TSB section.
Old 09-18-2015, 08:53 PM   #3
Celica00
Celica00's Avatar
Drives: 86
http://static.guim.co.uk/sys-images/...save-y-008.jpg
Worked like a charm for me and it was under 1.00$ to do. just stick one in the middle hole at the top of the trunk behind the seats
Celica00 is offline   Reply With Quote
Old 09-18-2015, 10:10 PM   #4
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
My dealer took care of it about a year ago. No problems. 100% fix. No idea how they did it. I'd definitely recommend letting the dealer do it if they're familiar with the problem. I had scarcely finished describing the symptoms and they offered to fix it for me. Another dealer about a year before that had no knowledge of the issue at all, so I think a lot depends on the service manager and personnel at the dealership in question.
NWFRS is offline   Reply With Quote
Old 09-18-2015, 10:53 PM   #5
lupindub
Drives: Scion FR-S
I have pin pointed the source of rattle and it sure aint coming from middle hole at the top of the trunk. It is actually coming from in between the passenger c-pillar and the rear deck. I don't think sticking ear plugs would do anything for my case.
Old 09-18-2015, 10:54 PM   #6
lupindub
Drives: Scion FR-S
I have done everything besides punch the spot welds. I will let the dealer take care of this if it comes down to this.
Old 09-18-2015, 10:55 PM   #7
lupindub
Drives: Scion FR-S
Cool. I'm curious which side the clicking noise was coming from for you guys? Mine seems to be coming from the passenger side right above the rear deck.
Old 09-18-2015, 11:17 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
I could induce it by hand just wiggling the spot-welded joints. I decided to see if the corrosion inhibitor would eventually cure or harden. Honestly, this is the first time I've thought about it in many months. I'll have to listen for it now.
Old 09-18-2015, 11:31 PM   #9
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
I used lithium grease and shoved foam pieces like in this video.
[ame="https://www.youtube.com/watch?v=i64gyvztiXA"]How to fix 86/FRS/BRZ Parcel Shelf Rattle - Project BRZ - Video 29 - YouTube[/ame]
sprintertrueno86 is offline   Reply With Quote
Old 09-18-2015, 11:35 PM   #10
PNW FRS
PNW FRS's Avatar
Give the dealer a shot
I thought I had the deck rattle and the dealer actually ended up fixing something with the trunk latch mechanism (which must have been loose or something) -- anyway... one visit... no more noise. 18 months later... still no issue. Enough time has gone by... enough dealers have had to deal with the "complaint" - so give them a shot. Not all dealers are crap...
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 09-19-2015, 05:03 AM   #11
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
This was my fix - haven't had any issues since - literally took seconds.
http://www.ft86club.com/forums/showthread.php?t=42065
nzer is offline   Reply With Quote
Old 09-19-2015, 12:23 PM   #12
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I have a noise from the rear that I think is the rear shelf rattle, but I'm not sure. I keep forgetting to mention it to the dealer. I'll probably ask about it next oil change.
Nevermore is offline   Reply With Quote
Old 09-19-2015, 01:50 PM   #13
Draco-REX
Corner Junkie
Draco-REX's Avatar
I punched all of the spot welds.
Old 09-19-2015, 03:31 PM   #14
kberkel
kberkel's Avatar
My knuckles are gonna be black and blue after this, I'll report back
kberkel is offline   Reply With Quote
Rear Deck Rattle? Fix it in 30s nzer DIY (Do-It-Yourself) Guides 66 08-21-2022 01:27 PM
Rear Deck Rattle from Sub Install mynameisnick4 Electronics | Audio | NAV | Infotainment 6 07-04-2014 03:23 PM
Rear deck rattle - fix it in 30s nzer AUSTRALIA 0 07-25-2013 04:09 PM
Rear deck popping/clicking DriftEightSix AUSTRALIA 6 02-01-2013 01:59 AM
do you think the rear deck rattle... pr086 Issues | Warranty | Recalls / TSB 7 08-03-2012 04:35 PM
