Drives: 2013 FRS
racerom flat foot shifting
so i've noticed on some vids, the rev limiter is kicking in on flat foot shifting. on mine, it just shifts into the next gear without it hitting the limiter. am i doing something wrong? do i need to set rev limiter to a higher number ?
[ame="http://www.youtube.com/watch?v=BA8qrWMwYH8"]http://www.youtube.com/watch?v=BA8qrWMwYH8[/ame] |
Thupercharged
What version of the visconti tune are you running?
I did notice with the supercharger and an older tune that flat foot shifting would sometimes just cause the revs to "hang" without activating the limiter.... usually only happened when revs were above 4K or so With 1.06 it seems like its working like it did when NA, maybe due to different race rom version from previous tune
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
| The Following User Says Thank You to DJCarbine For This Useful Post: | ft86me (07-25-2013) |
#3 | |
Drives: 2013 FRS
#4 | |
Thupercharged
Mine always just "rev limits" at the rpm that I push the clutch in at
2013 FRS
Drives: 2013 FRS
Drives: 2013 FRS
I actually tried it out and at 4.5k is my launch control limiter and when I had it floored I pushed the clutch in the jumper to 4.5 and was bouncing on the limiter. Maybe I should try it higher and see how it is after like 5. Hopefully the revs don't jump to red though
Drives: SWP Limited manual BRZ
what you are describing is definitely not happening in my car... I am using the most current stg 1 visconti tune that was released about a week ago. For me... regardless of rpm it holds it there for that brief moment where the shift is supposed to happen.
| The Following User Says Thank You to Norcalmav23 For This Useful Post: | ft86me (07-25-2013) |
Thupercharged
This is what mine does as well
2013 FRS
Drives: 2013 FRS
#10 |
Thupercharged
Found this in the racerom manual
"At the moment when the Flat Foot Shifting feature activates, a temporary rev limit is set thatis slightly higher than the current RPM. The ignition timing is retarded by a specified amountthat reduces engine torque while preventing the RPM from rising too rapidly."
2013 FRS
#11 | |
Drives: 2013 FRS
| EcuTek RaceRom Questions. | feldy | Engine, Exhaust, Transmission | 7 | 02-12-2014 04:07 PM |
| EcuTek racerom feature help | lbroskee | Engine, Exhaust, Transmission | 10 | 05-08-2013 10:45 AM |
| RaceROM Features Demo'd | JPxM0Dz | Engine, Exhaust, Transmission | 13 | 03-26-2013 09:39 PM |
| EcuTek RaceRom Flat Foot Shifting ! | Visconti | Engine, Exhaust, Transmission | 79 | 11-14-2012 09:36 PM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 05:09 PM |
