Drives: 2015 Scion FR-S
Remote door lock "chirp"
This might seem like a minor issue to many of you but it is a bother to me. The remote lock on my 2015 FRS makes a "chirp" when I lock and a double "chirp" when I unlock. The volume of that chirp is frequently too low for me to hear easily. I have to look at the lights to see them blink to be sure the signal was received. My previous Scions, a 2010 xB and a 2012 tC had a much louder chirp. I went to my local dealer to ask if there was a louder chirp available and was told "that's because it's really a Subaru" and not Toyota's fault! Anyway, does anyone have a simple solution to increase the volume of that chirp. Thank you.
Drives: GT86
Now that is a pretty good question, have thought about it myself.
Sent from my iPad using Tapatalk |
#3 | |
Drives: Ultramarine FR-S
I know the dealer can turn it off, that was the first "mod" I had done to the car. Not sure about turning up the volume on it. This thread by @Yruyur shows a lot of the changes that can me made (that's why I knew to ask for it to be turned off).
http://www.ft86club.com/forums/showthread.php?t=34502 Absolutely stupid that you have to have the dealer do this. My 2004 Suburban has all of these and more adjustable from the steering wheel controls.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#5 | |
Senior Misanthrope
I remember seeing somewhere that you can switch from the beep to the older-style short horn blasts. Might try googling for that. |
#6 | |
Drives: 2015 Subaru BRZ Limited 6MT WRB
Don't know but I would assume the settings are similar. You may have to go to Subaru to get it done though.
Drives: Toyota Highlander; Subaru BRZ (SWP)
I don't know if my aftermarket horns are the cause, but my "chirps" when locking and unlocking the car are probably 15db below the aftermarket horn's honk, which is still plenty loud.
Drives: 2015 Series.Blue
1) That sound is 100% Toyota as I've been fooled many times by Toyotas in parking lots
2) It's adjustable in Techstream and the idiots didn't want to do it 3) Hit the lock button on the remote 3 times and it'll honk the horn instead |
#10 |
Drives: GT86
Thanks Poodles will give that a try.
#11 | |
I have an appointment tomorrow with the Toyota dealer. He said he would give it a try and "maybe" it could be changed. We'll see. |
#12 | |
The Toyota dealer adjusted the volume of the remote key/lock "chirp" to my satisfaction using TechStream. All is fine now - much louder than before. |
#13 |
[||]--(86)--[||]
Drives: 2015 Firestorm FR-S
You can also customize a lot of settings, including chirp volume, using Carista (free android app). It requires an OBDII adapter though.
[||•]==(86)==[•||]
| 2015 Series.Blue Engine "Chirp"and 2nd Gear Grind | s30series | Issues | Warranty | Recalls / TSB | 33 | 09-07-2014 01:26 AM |
| CG Lock, "Mighty Tight", Baby Seatbelt Clip, or Schroth Rallye 4? | Kostamojen | Tracking / Autocross / HPDE / Drifting | 43 | 10-10-2013 08:10 PM |
| Air Conditioning "Chirp" | joelg | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 03-13-2013 09:57 AM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| Shutting off your "key-in-with-door-open" beeper -- it's very easy | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-13-2012 05:29 PM |
