Old 09-09-2015, 09:44 AM   #1
ArtS
Drives: 2015 Scion FR-S
Remote door lock "chirp"
This might seem like a minor issue to many of you but it is a bother to me. The remote lock on my 2015 FRS makes a "chirp" when I lock and a double "chirp" when I unlock. The volume of that chirp is frequently too low for me to hear easily. I have to look at the lights to see them blink to be sure the signal was received. My previous Scions, a 2010 xB and a 2012 tC had a much louder chirp. I went to my local dealer to ask if there was a louder chirp available and was told "that's because it's really a Subaru" and not Toyota's fault! Anyway, does anyone have a simple solution to increase the volume of that chirp. Thank you.
ArtS is offline   Reply With Quote
Old 09-09-2015, 09:48 AM   #2
ollie
ollie's Avatar
Drives: GT86
Now that is a pretty good question, have thought about it myself.
ollie is offline   Reply With Quote
Old 09-09-2015, 10:13 AM   #3
jonzhuxD
Drives: Ultramarine FR-S
The dealer should be able to adjust that for you with Techstream, it has nothing to do with the fact it's "really a Subaru".
jonzhuxD is offline   Reply With Quote
Old 09-09-2015, 10:53 AM   #4
I know the dealer can turn it off, that was the first "mod" I had done to the car. Not sure about turning up the volume on it. This thread by @Yruyur shows a lot of the changes that can me made (that's why I knew to ask for it to be turned off).
http://www.ft86club.com/forums/showthread.php?t=34502
Absolutely stupid that you have to have the dealer do this. My 2004 Suburban has all of these and more adjustable from the steering wheel controls.
Old 09-09-2015, 12:38 PM   #5
kch
Senior Misanthrope
kch's Avatar
Bullshit. Every toyota sounds the same as my BRZ. That part is 100% toyota.
I remember seeing somewhere that you can switch from the beep to the older-style short horn blasts. Might try googling for that.
Old 09-09-2015, 03:42 PM   #6
AzureShadow
Drives: 2015 Subaru BRZ Limited 6MT WRB
I assume that software works for the BRZ too correct? I'd ask in that thread, but it seems to have been dead for a while. A bunch of those are options I would love to be able to change.
AzureShadow is offline   Reply With Quote
Old 09-09-2015, 03:57 PM   #7
Don't know but I would assume the settings are similar. You may have to go to Subaru to get it done though.
Old 09-09-2015, 06:04 PM   #8
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
I don't know if my aftermarket horns are the cause, but my "chirps" when locking and unlocking the car are probably 15db below the aftermarket horn's honk, which is still plenty loud.
carma143 is offline   Reply With Quote
Old 09-10-2015, 01:01 AM   #9
Poodles
Drives: 2015 Series.Blue
1) That sound is 100% Toyota as I've been fooled many times by Toyotas in parking lots
2) It's adjustable in Techstream and the idiots didn't want to do it
3) Hit the lock button on the remote 3 times and it'll honk the horn instead
Old 09-10-2015, 08:48 AM   #10
ollie
ollie's Avatar
Drives: GT86
Thanks Poodles will give that a try.
Old 09-10-2015, 09:30 AM   #11
ArtS
I have an appointment tomorrow with the Toyota dealer. He said he would give it a try and "maybe" it could be changed. We'll see.
Old 09-11-2015, 11:12 AM   #12
ArtS
The Toyota dealer adjusted the volume of the remote key/lock "chirp" to my satisfaction using TechStream. All is fine now - much louder than before.
Old 09-11-2015, 12:35 PM   #13
Sosa
[||]--(86)--[||]
Sosa's Avatar
Drives: 2015 Firestorm FR-S
You can also customize a lot of settings, including chirp volume, using Carista (free android app). It requires an OBDII adapter though.
[||•]==(86)==[•||]
Sosa is offline   Reply With Quote
2015 Series.Blue Engine "Chirp"and 2nd Gear Grind s30series Issues | Warranty | Recalls / TSB 33 09-07-2014 01:26 AM
CG Lock, "Mighty Tight", Baby Seatbelt Clip, or Schroth Rallye 4? Kostamojen Tracking / Autocross / HPDE / Drifting 43 10-10-2013 08:10 PM
Air Conditioning "Chirp" joelg Scion FR-S / Toyota 86 GT86 General Forum 10 03-13-2013 09:57 AM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
