Drives: 2015 Series.Blue
Too much offset in rear?
Ive got the KW V3's installed with Enkei Raijins which are 18x8.0 with +45 all the way around and I've been having trouble keeping the rear planted during heavy cornering without breaking and steady throttle input. I have tried to increase front rebound but it still seems the ass slides out more than I think it should be on warm Direzza Z2's. Is it because my offset it too extreme and not enough of the tire is in solid contact with the pavement? Any suggestions or just going to a new wheel?
Only happy when it rains.
Drives: series.blue
what offset are you running?
What are your current suspension settings? Be as detailed as you can. It could just be suspension settings as that is the main cause of handling issues. |
Drives: 2015 CWP BRZ Limited
What's your alignment look like?
Updated with +45 offset and the alignment had 0 toe all the way around and somewhere around -1 degree of camber all the way around? Im not exactly sure on the exact specs it was aligned long ago.
Dismember
Drives: 2013 Red Scion FR-S
Springs, sway bars, shock settings and valving, alignment, tire inflation, and user inputs all matter.
Drives: WRB BRZ
Offset will play less of a roll in the percieved rear grip than alignment, suspension settings on kws, and tire pressures. I'd play with all those first before worrying about changing rim offsets.
Drives: series.blue
yea the settings on the suspension are what matters. KW V3's have a massive amount of adjustability. That is the settings you should be telling us. And what you should be playing with trying to eliminate what you are experiencing.
Señor Member
Did you get the alignment done after installing the KWs and wheels? Are you running the recommended bump and rebound settings on the KWs? Is this your first RWD car? Is it sliding too much when on the track, autocrossing or just on the street?
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | wparsons (09-10-2015) |
| Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision | n7011n | Exterior Parts (Aero, Lighting, Etc.) | 7 | 03-26-2014 04:46 AM |
| 205/55 16. 40 offset. Will they fit? | Nourdmrolnmt1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-02-2013 01:31 PM |
| What offset is legal? What offset provides most benefit? | bdohazelnuts | Tracking / Autocross / HPDE / Drifting | 2 | 02-08-2013 01:32 PM |
| Five AD Gunmetal R5:F Staggered with Falken FK-452's - Custom Rear Offset | digital_assassin | Wheels and Tires | 19 | 01-08-2013 04:03 PM |
| Stock wheel offset vs +38 in the rear | post_break | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 11-17-2012 11:15 PM |
