| FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum All photos, videos and other media related to the Scion FR-S and Toyota 86 |
Professional Smartass
Drives: White Out FRS
Stock wheel offset vs +38 in the rear
I hated the sucked in look on the rear wheels. So 10mm spacers and longer studs were in order. It was a hell of a modification labor wise and I think with the stock wheels you may want something closer to a 15mm spacer. I stuck with 10mm with the assumption I'll be going with a 17x8 +38 offset square in the future. This will give me aggressive stance without having to run staggered. And for track days I can quickly pull out the spacer and run stock offset with open ended lugs.
The spacers are hub-centric and I only suggest you use hub-centric spacers for safety. A DIY for replacing the rear studs is coming soon, we documented the process on my car for you folks. First three pictures are stock rear offset, the rest are with a 10mm spacer. It's hard to capture the difference since it's subtle but it definitely looks better. ![]() ![]() ![]() Below is 10mm spacer ![]() ![]()
| So, what's the stock offset? | rogerdalien | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 12-17-2018 10:47 PM |
| Stock Wheel offset | smbrm | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 09-15-2012 12:09 PM |
| wheel offset post pics! | gt86init | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 07-06-2012 05:23 PM |
| deep dish wheel offset | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 02-19-2012 06:45 PM |
| Wheel offset on watanabes? | Decameron | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 03-29-2010 05:20 PM |
