Old 05-16-2015, 09:52 PM   #1
Streetthrowback
Drives: 2015 brz
Navi radio randomly turns off while driving
Has anyone witness this?
Streetthrowback is offline   Reply With Quote
Old 05-20-2015, 03:52 PM   #2
Waffleicious
Waffleicious's Avatar
Drives: 2015 BRZ Blue Edition
This happened to me quite a lot after installing an aftermarket subwoofer. It had to do with incompatible frequencies from the line out to the amplifier. Problem was solved by insulating all tapped wires at all connection points and introducing a Line-Out-Converter.
Hope this helps
Waffleicious is offline   Reply With Quote
Old 05-21-2015, 08:53 AM   #3
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
There is a couple threads on this already
Do you use a USB drive for music?
Mine would shut off at higher volume, I replaced my USB and installed an OEM audio subwoofer, checked all connections on the back of the headunit
Haven't had it shut off since
Here is a thread on removing the headunit
http://www.ft86club.com/forums/showthread.php?t=30144
Here is a video
[ame="https://www.youtube.com/watch?v=kAWRRJcxWkI"]Subaru BRZ Stereo Removal - YouTube[/ame]
BlueSky is offline   Reply With Quote
Old 05-21-2015, 12:35 PM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Mine will occasionally reboot. I'd say it happens at least once a week. More annoyingly, though, is the more frequent issue I have of it kit acquiring a GPS signal lock for a good few minutes when I first start driving. This is irritating because those first few minutes are usually when I need it the most, lol.
Even MORE frustrating was that after 6 months of ownership, just the other day I turned it on and was presented with the "initial set-up" screen. It seems to have randomly reset itself and I lost all of my settings. It did keep my favorites on the radio and navigation, and my equalizer settings and such, but all my navigation history, all the recorded routes, and all the settings for navigation were gone. WTF!
Stang70Fastback is offline   Reply With Quote
Old 05-21-2015, 09:24 PM   #5
Streetthrowback
Drives: 2015 brz
I haven't taken the navi out yet, that's the reason why I posted
Old 05-23-2015, 11:31 AM   #6
Streetthrowback
Drives: 2015 brz
Spoke with my dealer they said they havnt encountered a problem like this, I dont like to give my car to the dealer because sometimes things happen, I'm going to look into this and keep you guys posted
Old 05-27-2015, 11:27 PM   #7
Djratrap
Drives: BRZ CSB Limited
Just had it happen today randomly. Turned off then back on while driving.
Djratrap is offline   Reply With Quote
Old 05-30-2015, 02:27 PM   #8
Eski
Eski's Avatar
Drives: '15 Brz Series Blue
The unofficial cause of this (because i had this issue to and it pissed me off and the techs at my work didn't believe me because its so intermittent) is get a smaller usb drive. If you have too big of a usb drive plugged in then the head unit can't handle it and resets itself, sometimes briefly and sometimes fully. Try smaller usb sticks for your music/videos and what not.
"Listen, smile, agree and then do whatever the fuck you were going to do anyway." -Robert Downey Jr.
Eski is offline   Reply With Quote
Old 06-01-2015, 09:11 AM   #9
BlueSky
BlueSky's Avatar
I agree
There seems to be a lot of issues and we all have the same variable
A USB, I read somewhere that 64 GB did not read, but I cannot confirm this
When I was doing trial and error, I just formatted the Drive fresh and put music on directly to flash (not in folders or anything like that)
I would try that and see
Old 06-03-2015, 01:20 PM   #10
Eski
Eski's Avatar
Originally Posted by BlueSky View Post
I agree
Yeah it seems that folders corrupt it as well as the size of the drive. I had a small drive with folders and it still crashed. Once i took the folders out I havn't had any problems since..It's only been 5 days tho.
Old 06-03-2015, 04:00 PM   #11
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
I had a similar problem that went on for weeks. The unit would reboot and have me go through basic set-up every time, which was incredibly annoying...almost like it was updating the s/w, which it wasn't. Eventually, it stopped and I have no reason why. Today, it works fine with no issues with a 256gb USB Drive...with folders...
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 11-27-2015, 09:00 AM   #12
SasaGT86
Drives: Toyota GT86 Lightning Red MT
I have the same problem. Mine turns off when the Auto lights turn on and off so if I drive in the tunnel the radio turns off. It doesn't happen every time but it's happening more and more
SasaGT86 is offline   Reply With Quote
Old 01-10-2016, 07:40 PM   #13
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
I can confirm that if you put all your music into one folder, the problem will cease.
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Pressing Brake Turns off Clock/Dims Navi Foobar Issues | Warranty | Recalls / TSB 18 11-01-2021 02:36 PM
Radio shutting off/resetting itself while driving Eski Electronics | Audio | NAV | Infotainment 7 05-21-2015 09:06 PM
AC HVAC turns on randomly DarkestBuddha Electronics | Audio | NAV | Infotainment 0 06-28-2014 08:53 PM
About the New Radio Unit/Navi Unit for FR-S yangtaotai Scion FR-S / Toyota 86 GT86 General Forum 21 07-09-2013 12:27 PM
Auto Climate Control turns on randomly cantaloupe BRZ First-Gen (2012+) — General Topics 18 03-14-2013 08:38 AM
