Old 08-31-2015, 03:58 PM   #1
OkieSnuffBox
Drives: '23 BRZ Limited
HPDE/TT guys running E85, mpg?
Trying to get an idea of how much E85 I'd use at my local track over a weekend, 5 sessions a day 15-20 minute sessions on a 1.8 mile track.
Typically 8 timed laps + cool down lap, last session of the day (if it's thinned out) they may give us 10/11/12 laps.
I can buy a 55 gallon drum of quality, guaranteed E85 fuel and have it at the track ready for me.......just not sure how much I'd actually use? And I'd prefer to use E85 at the track for the extra oomph and the lower temps.
Any idea? Our tanks are 13.5 gallons?
Old 08-31-2015, 04:24 PM   #2
wparsons
wparsons's Avatar
It'll depend on how much time you're on the throttle (more open tracks will use more gas), but I typically drain a full tank of 94 in a lapping day. That would be six or seven 15 minute sessions. With e85 running richer already, plus making more power, I would guesstimate you're going to need 30% more fuel per day on a similar track.
Assuming I would burn about 12 gallons of 94 on a tighter track, adding 30% is ~15.5 gallons per day. Even if I'm not super close, you're still well under 55 gallons in a weekend. Your mileage would have to be a 100% increase over mine to burn up close 55 gallons in a weekend.
I've emptied my tank many times here:
I haven't run any full days on the CTMP GP track, but I've gone through about half a tank in two 20 minute sessions:
flickr
The Following User Says Thank You to wparsons For This Useful Post:
OkieSnuffBox (08-31-2015)
Old 08-31-2015, 04:26 PM   #3
juliog
juliog's Avatar
Drives: 86
I've heard ~30% increased fuel consumption on E85 for NA cars, compared to 91/93.
juliog is offline   Reply With Quote
Old 08-31-2015, 04:51 PM   #4
Jonsey
Jonsey's Avatar
I used to run E85 at the track but had to give it up when the aero was installed because of fuel starvation on long fast left handed sweepers. I would drive 50 miles to the track and carry 12 gallons of fuel. I could do 4-20 minute sessions and drive back home and be at less than 1/8 of a tank left including using the 12g I carried with me.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
The Following User Says Thank You to Jonsey For This Useful Post:
Old 08-31-2015, 05:20 PM   #5
sstfnv
sstfnv's Avatar
My car usually uses a little less than 1/4 tank E85 per 20 min session and on the way to the track it does 23-27mpg depending on the speed and traffic.
sstfnv is offline   Reply With Quote
The Following User Says Thank You to sstfnv For This Useful Post:
Old 08-31-2015, 05:38 PM   #6
OkieSnuffBox
I'm aware, but I haven't had this car out on track yet.
Only MPG experience I have at my track is on an R6 and my last Miata, not really relevant to the BRZ.
@Jonsey do you have more details on your suspension/wheel/tire/aero setup?
Also, at what fuel level on the guage were you having issues?
Just trying to get as much info as I can first. I might see if anyone else locally runs it and see if they want to split a barrel, but not sure 28 gallons will get it done for the whole weekend.
Old 08-31-2015, 05:51 PM   #7
Jonsey
Jonsey's Avatar
Running Koni yellows and Swift Spec R springs, FT86 Front Splitter w/ race upgrade, DWL Type 1 rear diffuser, 235/35/17 ZII Star Specs, stock motor other than tune and running rear LCA and camber plates (well sorted now), I would get fuel starvation at just above 3/4 tank on 2 back to back fast left handed sweepers. I was no longer able to run a full session before getting fuel starvation so I went back to pump gas.
Old 08-31-2015, 06:12 PM   #8
I average around ~4MPG...
Old 08-31-2015, 06:13 PM   #9
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
One third of a tank per 20 minutes pushing hard
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following 2 Users Say Thank You to Deep Six For This Useful Post:
CSG Mike (08-31-2015), OkieSnuffBox (08-31-2015)
Old 08-31-2015, 06:24 PM   #10
OkieSnuffBox
Yikes, that's bad! I didn't realize the cars were that sensitive to fuel starvation.
We could run the Miata on Rcomps down below the E mark and not get fuel starvation, but no super long sweepers at Hallett really either.
Old 08-31-2015, 07:14 PM   #11
OkieSnuffBox
Old 08-31-2015, 08:40 PM   #12
wparsons
wparsons's Avatar
I don't think 28 gallons will be enough for the weekend, on the local tighter track that would barely be enough 94, add the extra consumption for e85 and you'll probably run out.
2 barrels between 3 people is probably the sweet spot for a tighter track.
flickr
Old 08-31-2015, 09:24 PM   #13
Jonsey
Jonsey's Avatar
Unfortuntely with E85 you are pushing the fueling system pretty hard and the tank is raised in the middle and the pickup is only on the bottom of the left part of the tank. PST has a chart showing some fuel pressure drops while running 93 at pretty full tank levels, the effect is just not as pronounced on gas. If you are familiar with MSR Cresson, the starvation happens after the horseshoe/boothill/tombstone complex and big bend when going ccw.
Old 08-31-2015, 09:36 PM   #14
OkieSnuffBox
Thanks, good to know. I'll start asking around with the track guys.
Damn. The old E30s used to be like that (the hump that is), but there was a small pump that pushed fuel to the other side for the main pickup.
So really this car needs a surge tank............ugh.
Any you guys running a single muffler exhaust? exE36M3 Northern California 28 02-21-2016 10:03 PM
what lugs nuts you guys are running? enjoi23 Tracking / Autocross / HPDE / Drifting 40 11-11-2015 11:12 AM
How do you guys running 18x9.5 in the front do it? ysr50guy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-04-2014 01:49 PM
Guys running EcuTek boost control ATSAaron Forced Induction 14 09-14-2013 03:08 PM
what upgraded pads are you guys running? ft86me Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-18-2013 12:22 PM
