Old 08-25-2015, 03:08 PM   #1
JG
JG's Avatar
Drives: Whiteout FRS
Cold start
Anyone else get a delayed start up primarily in the morning? It started happening after i switched to E85. I'm on the open flash tablet E85 UEL header tune if that matters. I've never had a failed start up and it works perfectly after the first one of the day.
JG is offline   Reply With Quote
Old 08-25-2015, 03:09 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Seems to be a common issue with E85. Wouldn't sweat it
https://www.google.com/search?q=e85+...UTF-8&hl=en-US
Freeman is offline   Reply With Quote
Old 08-25-2015, 03:10 PM   #3
fika84
fika84's Avatar
If you search this you will find multiple threads talking about the effects of the cold with e85. LMGTFY
fika84 is offline   Reply With Quote
Old 08-25-2015, 03:43 PM   #4
kch
Senior Misanthrope
kch's Avatar
As others have said, it's common. It will be worse when it gets colder outside. You might see some improvement if you turn the ignition "on" for a moment before actually starting the engine. This will prime the fuel pump.
Still not a real fix, though.
Old 08-25-2015, 04:48 PM   #5
JG
JG's Avatar
Gotcha. As long as it is not a huge problem i'm fine with it. Just had to check.
Old 08-25-2015, 04:57 PM   #6
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I had this same problem with my 03 wrx. I let my mom drive it for the first time and she did not click the ignition to let the fuel pump prime before turning on and it was the worst turnover i've ever heard. We drove down the street and i saw there was a check engine light on. It was 2 missfire codes for cylinders 1 and 3. I wiped it and never had that problem again. Then 3 weeks later I blew a head gasket >.< I don't think theyre related at all though.
Instagram: trevor.parque
Old 08-25-2015, 08:15 PM   #7
steve99
Modify the cranking injector pulse width tables
copy them out of one of wayno's tunes see his thread here they are A01G/I tunes just copy the cranking ipw tables from tunes into yours C or D series E85 rom.
will start first crank
see thread here (use his definitions as well
OFT Tunes for Automatic Transmission, E85 fuel economy and Stg1, Stg2 and BPB maps for 98RON
Old 08-25-2015, 08:37 PM   #8
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
The post start timing and maf adjustments help immensely also, to the point where it starts first crank at about 5C on most cars. After all that if it still takes 2 cranks, do the first with your foot flat on the throttle.
Also, this topic is in the wrong forum in addition to being redundant.
Old 08-29-2015, 02:55 AM   #9
JG
JG's Avatar
This is entirely too advanced :0
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold start question ggiddix Engine, Exhaust, Transmission 8 02-06-2015 10:27 PM
Cold weather start oppiee CANADA 57 01-16-2015 03:20 PM
E85 cold start Turdinator Software Tuning 8 08-29-2014 11:12 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
