CANADA Canada
Old 01-07-2015, 06:23 PM   #1
oppiee
Drives: 2014 Scion FRS (Red)
Cold weather start
Freezing today, took a good 5 seconds before the car started.
Then I hear some knocking. I have had that knocking since winter, but its worse in the cold. Anyone have the same issue?
oppiee is offline   Reply With Quote
Old 01-07-2015, 06:27 PM   #2
Bergen23
Drives: '15 Halo FR-S
I once had a long start. However, I let the fuel injectors warm up before I start the car. Usually 15-20 seconds before I crank it. That could be the long start issue if you tried to just turn it over immediately.
As for the knocking, not a clue. Have you ever taken it to the dealer or a shop to get it diagnosed?
Bergen23 is offline   Reply With Quote
Old 01-07-2015, 07:16 PM   #3
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Uhmmmm wat?
Do you mean let the fuel pump prime to build pressure?
BRZZZZZZZZZZ is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZZZZZZZZZZ For This Useful Post:
FRSBRZGT86FAN (01-07-2015), White_ghost_of_akina (01-08-2015)
Old 01-07-2015, 07:28 PM   #4
Sweet48
Sweet48's Avatar
Drives: 2013 Subaru BRZ
Knocking could be from the ultra cold oil and it not flowing into the motor fast enough. Not 100% on that one but someone feel free to say "shut up, you dont know what you're talking about".
Also priming the fuel pump prior to very cold starts is a good practice.
Sweet48 is offline   Reply With Quote
The Following User Says Thank You to Sweet48 For This Useful Post:
Chad86 (12-07-2016)
Old 01-07-2015, 07:42 PM   #5
D_Thissen
D_Thissen's Avatar
It was freezing up here in Tbay (-30 before the wind last night). I plugged in the block heater for about an hour and a half this morning and she fired right up. 0W20 oil is amazing! I never had a problem in Whitby with the cold though.
Old 01-07-2015, 07:59 PM   #6
Bergen23
Originally Posted by BRZZZZZZZZZZ View Post
Uhmmmm wat?
Oh dear, sorry I used an incorrect terminology. Maybe for someone who I presume has been an auto enthusiast for a while, you could be less of a ****head to someone new to the game and cut the condescension.
Old 01-07-2015, 09:46 PM   #7
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Don't worry about the "knocking". It's just small afterfires. Anyone that has heard an old rotary starting up will know exactly what I'm talking about.
The only thing I do in the winter is let the fuel pump run before turning the key, and then I let the engine run while I scrape all the snow and ice off of the car.
After that, I drive in first gear slowly all the way down my street. That helps circulate things in the transmission a bit. Without it, I can't get into second gear easily.
Two minutes later the car is as ready as it will ever be. HTH.
pushrod is offline   Reply With Quote
Old 01-07-2015, 09:48 PM   #8
pushrod
Benched 86lb
pushrod's Avatar
Welcome to the internet.
The Following User Says Thank You to pushrod For This Useful Post:
D_Thissen (01-07-2015)
Old 01-07-2015, 10:03 PM   #9
Bergen23
I always forget that people aren't exactly patient, or polite. I blame my motorcycle, as it has a red light with FI underneath it while the fuel pump is priming and that's what I thought of when I typed the post.
Old 01-08-2015, 06:57 AM   #10
wparsons
wparsons's Avatar
Forget about cold starts, you *should* always let the pump fully prime before cranking the engine over. You can hear it if you listen, but if you wait for the fuel gauge to move to however much gas you have left that's typically long enough.
As for the cold starts, I definitely get some after fires or mis fires when it's really cold, they go away once there's a bit of heat in the engine (like 30 seconds of idling).
It was cold enough last night that with the clutch out in neutral the idle actually dropped a couple hundred RPM from the drag of the gearbox fluid, and even made the car lurch forward a couple inches.
flickr
The Following 5 Users Say Thank You to wparsons For This Useful Post:
Chad86 (12-07-2016), daiheadjai (01-08-2015), Pkush (01-08-2015), PMPB (01-17-2015), Tcoat (01-08-2015)
Old 01-08-2015, 08:53 AM   #11
BRZZZZZZZZZZ
Car Nut
I suggest you leave the forum now if you think that was rude, because your gonna be butthurt about a lot more things around here.
The Following User Says Thank You to BRZZZZZZZZZZ For This Useful Post:
Wilso (01-08-2015)
Old 01-08-2015, 11:13 AM   #12
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
[QUOTE=wparsons;208215
It was cold enough last night that with the clutch out in neutral the idle actually dropped a couple hundred RPM from the drag of the gearbox fluid, and even made the car lurch forward a couple inches.[/QUOTE]
I find mine does the same any time it's been sitting in the real cold weather.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
The Following User Says Thank You to FLYFISHR For This Useful Post:
wparsons (01-08-2015)
Old 01-08-2015, 11:22 AM   #13
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Don't boxer engines get piston slap when really cold?
Old 01-08-2015, 12:00 PM   #14
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Good to know - I have not been priming my fuel pump before starting.
It hasn't been an issue since I park in underground garages most of the time, but this is certainly going to be useful...
daiheadjai is offline   Reply With Quote
TPMS IN COLD WEATHER Scionshaun Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 11-20-2016 06:27 AM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
e85 in NY cold weather whitefrs Forced Induction 5 12-10-2013 09:52 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
rattling in cold weather mezdup Issues | Warranty | Recalls / TSB 2 01-22-2013 09:32 AM
