Old 05-16-2015, 08:22 PM   #1
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
FS: HVT Non-raising camber plates & WL camber bolts
FS: HVT Non-raising camber plates and Whiteline camber bolts. These are for OEM size springs. $375 Shipped.
With 17x9 +35 RPF1's and 255 wide tires I was able to get 3.2 degrees of camber. With stock wheels you can probably get more. I was limited by tire closing in on the spring, so couldn't go full negative with the camber bolt.
Great solutions for an STX car on lowering springs instead of coilovers!
trippinbillies40 is offline
Old 05-16-2015, 09:00 PM   #2
trippinbillies40
Drives: '22 WRB
Sold already! Woot!
Camber bolts: Max camber tricks bfrank1972 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-03-2014 10:01 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
