Drives: 2023 BRZ
Alignment with stock suspension + camber plates
I can't believe I don't see a thread on this topic already, so I guess I'll start my own. My BRZ is on OEM suspension. I already have crash bolts and will soon be adding camber plates to it. Immediately after installation of said plates I will be getting an alignment. Here are my questions:
1. Camber will now be adjustable at the top (plate) and bottom (bolt). Which should be adjusted first? Or should they just leave the camber bolt (presumably) maxed out where it is now and only adjust with the plates? 2. What should my goal be for front and rear camber, given the suspension is stock? I like the balance of the car as it is now and don't want it to be super loose at the track. I would be comfortable with it loosening up a little, just not drastically. 3. Should I run different camber on the street vs. track? I'm guessing not, since I'm still on street tires at the track. My concern is adding significant front camber without adding any in the rear. Any other thoughts would be appreciated. |
#3 | |
Tracking the car? Assuming sticky-ish tires, -3 front -2.4 rear. You'll need a rear LCA for this. The most probable reason for no answers, is that this question comes up all the time. I do understand the search function is not the most useful... |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | CatDaddysBBQ (08-21-2015), Ultramaroon (08-17-2015) |
Drives: 2023 BRZ
Thanks, Mike. If I don't have LCAs and am therefore limited to stock rear camber, what do you think the most camber I should do in front is?
#6 | |
Drives: 2022 BRZ Limited
Can I ask you what kind of tire,wheel setup you're planning to run on your BRZ w/ OEM suspension?
See below for the answers: Quote:
FWIW when I was running ~2.5 degrees on the street I hopped out after a short drive to see how they were wearing after several hundred miles, no significant wear at that point but when I felt them the inside edges were hot while the rest of the tire was cool. If you're concerned about tire longevity I'd go back to less camber for street driving via camber plate adjustment, mine are easily done in 5 minutes and the change in toe is unnoticeable from the butt dyno- I mean butt alignomometer as well as confirmed when I got it aligned last time, went from -1.1 to -2.7 with the biggest toe number being 5/32" (still within factory specs iirc).
| The Following User Says Thank You to strat61caster For This Useful Post: | CSG Mike (08-17-2015) |
Drives: 2023 BRZ
Hey guys, thanks so much for sharing your experience and wisdom with me.
I can't get more than about 1.2 degrees of camber up front with only crash bolts. That's why I went with camber plates. For the rest of this summer I'll be burning up the remainder of my HTRZ-IIIs. Not a great tire, but it gets the job done. Next spring I'll be on something like an RS3/RE71 or perhaps RC1. More than likely RS3/RE71, though. It sounds like I should shoot for zero toe all around (no change) and get as much camber at both ends as I can. Well, I guess there really is no camber adjustment at the rear right now for my car. I expect this will be 2.5 to 3 up front. I'll keep an eye on inner shoulder wear the rest of this summer. After the OEM shocks become less effective in a year or two, , I'll likely be on T2s with something like an RC1. Again, thanks for the help. Sorry my search skills must need a little improving. Last edited by Pat; 08-18-2015 at 12:03 PM. |
#9 | |
While the RE71R is marketed as a 200TW tire, it certainly doesn't grip or wear like one. It's much more on par with the typical 80TW. |
#10 |
Drives: 2023 BRZ
Thanks, Mike. I'm aware of this. I'm not running my first choice in tires, and may not next year either. The same can be said of suspension. It is a slow process to get the car to where I want it, as I have other priorities.
| WTB: caster/camber plates - Or rear suspension alignment pieces | STS-V | Want-To-Buy Requests | 0 | 06-27-2014 09:24 AM |
| Cheapest way to get more camber on stock suspension | Snake | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-11-2014 08:45 AM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
| Tein S-Tech, Stock Wheels, Camber Bolts, Alignment. Yes, I've used search already. | Shiro86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 08-14-2013 09:44 AM |
| FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) | serial gixxer | Brakes, Suspension, Chassis | 18 | 05-20-2013 08:51 PM |
