Old 07-17-2015, 08:39 PM   #1
Killianti
Killianti's Avatar
Drives: 2013 WRB BRZ 6MT
Tie rod ball joint stuck
I'm trying to replace my tie rod ends using thw Whiteline bump steer and roll center correction kit, but I can't get the ball joint on the end of the driver-side tie rod to separate from the hub assembly. I removed the cotter pin and castle nut, but nothing I do seems to move the ball joint. Am I being stupid or missing something?
Killianti is offline   Reply With Quote
Old 07-17-2015, 08:55 PM   #2
Fishbone
Drives: 2024 GR86
Put the castle nut on an try hitting it with a hammer. . Be careful not to damage the treads. Make sure the tie rod is flush with the nut to ensure maximum thread engagement.
Fishbone is offline   Reply With Quote
The Following User Says Thank You to Fishbone For This Useful Post:
whataboutbob (07-17-2015)
Old 07-17-2015, 09:29 PM   #3
Killianti
Killianti's Avatar
This doesn't seem to help at all. I mean, there is no movement between the ball joint and the hub. Do I just need to hit it harder or something? I put a block of wood between the ball joint and the hammer, and i'm mostly just putting dents in the wood.
Old 07-17-2015, 09:49 PM   #4
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
You've probably tried it already... but try wanging in shear.
For stuck ball joints, here's my strategy:
  1. Spray the top of the threads with plenty of PB Blaster (or WD40 in a pinch).
  2. Wait a while.
  3. Wipe down the exposed surfaces.
  4. Use a hammer (and a large steel punch, if helpful) to sharply hit the steering knuckle in the fore-aft and lateral directions.
  5. Use @Fishbone 's method to push the ball joint stud out of the knuckle.
  6. If that failed... I'd break out the pickle fork and use a small sledge (this kills the crab).
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following 2 Users Say Thank You to Shankenstein For This Useful Post:
Calum (07-17-2015), DieselDog (07-18-2015)
Old 07-17-2015, 10:09 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
  2. Wait a while.
  4. Use a hammer (and a large steel punch, if helpful) to sharply hit the steering knuckle in the fore-aft and lateral directions. Sometimes I resort to an air hammer. I don't use a lot of pressure, though.
In bold.
Old 07-17-2015, 11:01 PM   #6
Fishbone
Drives: 2024 GR86
Using a piece of wood reduces the effectiveness of the hammer blows. Hitting the nut will not damage anything.
If that still does not work, use a jack to raise the hub and hit the nut again. Its possible the dropping suspension on jack stands in binding the tie rod in the knuckle.
Old 07-17-2015, 11:54 PM   #7
ryoma
ryoma's Avatar
buy a ball joint puller tool. you can buy one at harbor freight or amazon for like 10 bucks. it's a U-shaped tool with a threaded bolt in the middle (use a wrench to turn the bolt) and it applies pressure to push the other end out. make sure you buy the right size though so that the tool has leverage. I haven't changed anything suspension-wise on my BRZ, but it made everything so much easier on my MR2 when I replaced the ball joints and tie rods.
Old 07-18-2015, 12:23 AM   #8
DieselDog
Shift it or lose it
DieselDog's Avatar
Drives: 2014 FRS, 2003 Celica GT
  2. Wait a while.
I like to put the castle nut on upside down if I feel I need to hit it but usually when you hit the knuckle where the tie rod end goes into it usually just falls out.
70% of the time. lol
DieselDog is offline   Reply With Quote
Old 07-18-2015, 12:36 AM   #9
Killianti
Killianti's Avatar
I'll get back on it tomorrow morning, but the whole thing feels like it's welded together. It's probably not safe to take a torch to it right next to that dust boot. It and a few nuts are soaking up PB Blaster tonight.
Old 07-18-2015, 12:51 AM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
Ball Joint Separators Choose your poison. I've always used pickle forks but the hinged tool might work. It's a tapered pin in the hole and they do lock together just shy of being welded. I've had to beat the shit out of bigger ones to get them apart.
GhostRai (07-18-2015)
Old 07-19-2015, 11:00 AM   #11
Killianti
Killianti's Avatar
I was able to get it out using a too-small, clamp-style ball joint separator and a hammer to keep it in place. Thanks for all the help.
Old 07-19-2015, 01:26 PM   #12
Ultramaroon
not playing cards
It was a bitch, wasn't it?
Old 07-19-2015, 02:34 PM   #13
Uncle Benz
Uncle Benz's Avatar
Drives: GT86
For future reference, I often find the success of a hammer is usually down to the size chosen and the anger behind it. Tickling it with a toffee-hammer seldom results in much.
Uncle Benz is offline   Reply With Quote
The Following User Says Thank You to Uncle Benz For This Useful Post:
Ultramaroon (07-19-2015)
Old 07-19-2015, 10:32 PM   #14
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Did the whiteline balljoints stay in after installation?
The biggest issue with removing the tie rod is removing other parts first, some people will remove the strut housing from the steering knuckle, it's best to keep that all in place and remove the tie rod first.
Need some help, how to disingage the rear UCA ball joint. Calum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 05-07-2015 03:52 PM
Rear upper control arm ball joint? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-06-2015 07:17 AM
Ball Joint Replacement, The fun way. FRSPacNW DIY (Do-It-Yourself) Guides 2 06-28-2014 03:04 AM
Front ball joint dimensions J-W Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-02-2013 05:31 PM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 01:16 PM
