Old 05-07-2015, 10:50 AM   #1
Calum
That Guy
Drives: 2013 asphalt FRS MT
Need some help, how to disingage the rear UCA ball joint.
Hey guys, I'm trying to get some bushings installed and these ball joints are really holding things up. I've got all of the bolts out of the control arm. I can get some movement of the ball joint stem, but only about a quarter of an inch. After that it just comes to a hard stop.
Any help would be really appreciated!
Old 05-07-2015, 11:09 AM   #2
wparsons
wparsons's Avatar
I remember reading somewhere you need some force to get them out, safest way would be a balljoint fork, but a big hammer will probably do the trick as well.
Do the rear knuckles have a pinch bolt, or just a bolt that locks in with a groove on the ball joint? If it's a pinch bolt you might have some luck opening up the knuckle a bit with a prybar (where the pinch bolt would hold it closed).
flickr
Old 05-07-2015, 11:17 AM   #3
Calum
That Guy
I've got the pinch opened, that's the only way I was able to get any movement at all.
Thanks though, keep it coming guys.
Old 05-07-2015, 12:46 PM   #4
Calum
That Guy
Never mind. I was hoping for an elegant answer but in the end it just needed more brute force and ignorance than I was expecting.
The Following User Says Thank You to Calum For This Useful Post:
Tcoat (05-07-2015)
Old 05-07-2015, 12:46 PM   #5
wparsons
wparsons's Avatar
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
Calum (05-07-2015), cdrazic93 (05-07-2015), Tcoat (05-07-2015)
Old 05-07-2015, 01:11 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Yeah. Its a bitch. I just kept using a bigger hammer when I did mine
wparsons (05-07-2015)
Old 05-07-2015, 03:22 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Dont forget the half of that engineers flow chart! If its supposed to move and it doesnt, WD40 that sum bitch
The Following 4 Users Say Thank You to cdrazic93 For This Useful Post:
Calum (05-07-2015), finch1750 (05-07-2015), tahdizzle (05-07-2015), Tcoat (05-07-2015)
Old 05-07-2015, 03:52 PM   #8
Calum
That Guy
Yeah, for a second I thought I was gonna need my ford hammer.
It's A Ball, Low & Outside........... White64Goat Scion FR-S / Toyota 86 GT86 General Forum 8 01-18-2015 01:15 PM
Rear upper control arm ball joint? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-06-2015 07:17 AM
Ball Joint Replacement, The fun way. FRSPacNW DIY (Do-It-Yourself) Guides 2 06-28-2014 03:04 AM
Front ball joint dimensions J-W Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-02-2013 05:31 PM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 01:16 PM
